Demtor Posted November 24, 2011 Posted November 24, 2011 Hello! I am very new to autoCAD and I am using autoCAD 2011. I have a problem. If I do a drawing in autoCAD in mesarments that they should be in real life. For example if wall is 9000mm long I type in 9000. Building plan like that is easier for me. But problem comes when I try to plot it to scale 1:100 for ISO A3 paper (420x297) How Can I make it fit perfectly and be in-scale? And another question. If I want to have a frame around my drawing and corner frame with name of the work, who did it etc etc. so I don't have to do it over and over again on every single new drawing. How can I do it? I heared I can use blocks. But how do I fit my block to a certain scale? If I make my block in 420x297 which is A3 standard and do a drawing with 1000- mesarments than it simply will be small for it. I hope you can understand what I mean. Any help would be appreciated! Alexander Quote
Tiger Posted November 24, 2011 Posted November 24, 2011 I recommend that you start using the Layout. On the Layout you create a Viewport (command MVIES) that works as a sort of window into your Model Space. You can zoom in that window to your correct scale and still have the LAyout as a proper A1 paper. Quote
ReMark Posted November 24, 2011 Posted November 24, 2011 Draw your objects, just as you did, full size in model space. After doing that you switch to a layout as Tiger suggested. In your layout you are going to create a viewport. A viewport is nothing more than a window that allows us to see the objects we created back in model space. The trick to correctly depicting something as large as a building on a small sheet of paper, to scale, is to assign a scale (appropriate to the sheet size you'll be plotting to) to the viewport itself. That's right, a scale is applied to the viewport. You can have up to 64 viewports in a single layout and you can assign each a diiferent scale if need be. Viewports are created with the MVIEW command. Viewports should be placed on their own layer and the layer should be set to "no print". Viewports can be resized using Grips. They can also be copied, rotated or even deleted. After your viewport is set up the way you want (showing your geometry as you want) its display should be locked to avoid inadvertently changing it. As far as your title block and border goes I'd suggest creating one that suits your needs for the size paper you'll be using the most often and save this in a layout as a template file. Use this template file (you can have more than one template file) whenever you start a new drawing. Can your title block and border be a block? Yes it can. You might also look into filling in the title block via attributes. When using a layout and you are ready to plot you do so at a scale of 1:1 and let AutoCAD take care of plotting the objects in your viewports correctly based upon the scale that has been assigned to them. You have a lot to learn but you have come to the right place to start the process. That just leaves dimensions and text. You have two choices. You can place these objects either in model space along with your geometry or place them in your layout. There are pros and cons to each method. You might want to experiment first and see which method works best for you. Quote
Demtor Posted November 25, 2011 Author Posted November 25, 2011 Thank you so much! That was very helpful! Quote
