I cannot seem to debug a simple vb.net program. I am new to .net programming, but i think i should be able to debug from vb express.
Here is my setup:
  • Windows 7, 64 bit
  • Vb 2010 express running in admin mode
  • AutoCAD map 3D 2011
  • referenced acmgd and acdbmgd from objectarx 2011 and set to copy local = false
  • compiling to .net 3.5
  • using the AutoCAD .net wizard to generate a template
I can start the debug process, watch AutoCAD load, netload my dll from the debug directory, type my command and watch the program run with out error, but i cannot get it to halt at a break point. Any ideas?
Sounds like you need to modify the acad.exe.config file; note the XML commented notes. :wink:
