Hello Everyone
Is there any command for automatic numbering?
Instead of editing one by one.
For example i have text 1 and i copy the text 1 to multiple, lets say 100 text 1 numbers. How to edit them into from number 1 to number 100.
It is always worth scrolling down to the bottom of this Forum thread page to check out Similar Threads. I think you will find out what you want. :)
You do not need to post in different sections of the Forum, because all new posts are viewed in one section.
Express---->Text---->Automatictextnumbering
Hello Everyone
Try this link:
http://www.theswamp.org/index.php?topic=518.0
Download the Text Increment program that CAB made. I use it almost every day, works great. :)
  • 1 year later...
Encountering the same problem but need a lisp routine to edit the attributes which are nos. within a block to solve the same...
Any help shall be really appreciated
Post your sample drawing with this block only
~'J'~
~'J'~
Here is the sample drawing... The Banded Tendons Sheet start with 1 Nos. and according to the color and symbols, are numbered by dynamic Block with attributes.... Now if there is any modification in the nos. of tendons as per conditions, in Banded then the entire numbering has to be started all over again....
A LISP Routine for Tendon Nos. modification by clicking on it and then automatically all the related Tendon Nos. getting automatically updated as far as numbering is concerned shall be of great help and use....
$PTS-4-2C.zip
other file missing is attached herewith
$PTS-4-3C.zip
I haven't understood what you exactly need,
could you send a picture on which the situation after program
performance would be shown?
As it has been shown for beam :)
~'J'~
~'J'~
Thanks fixo for offering help and I shall definitely do the pre-requisite but may be in a day or two since I am keeping busy in some other office regular routines... But I shall keep u updated; In the meantime you might also finish up with your work as I came to know thru' your quote to Mardi....
See ya
Thanks so much again!!!
See ya
Ok I'll watching this thread
Cheers :)
~'J'~
