NirantarVidyarthee Posted December 2, 2011 Posted December 2, 2011 Is there any online Glossary available that can explain the terms / concepts used in AutoCAD Electrical? For example - what is a PIN? OR what is the difference btween linking two components and connecting them by wires? I am not an Electrical Engineer but need to use ACE for some specific purpose. Or any other resources that explains electrical fundas? I don't need very detailed info but just need to know the concepts. Thank you for any info. Quote
ReMark Posted December 2, 2011 Posted December 2, 2011 A pin would be a physical connection point on a component (i.e.-something a wire could be connected to). If one links two components I would think they are establishing a parent-child relationship. Connecting an on/off pushbutton with a contact, solenoid or a temperature switch is just that...a physical connection and not necessarily the same as a relationship. That would be my interpretation but I'm no electrical engineer so I very well could be wrong. Perhaps someone will come along and educate both of us. Quote
