mehrdad Posted December 4, 2011 Posted December 4, 2011 Hello Please let me for the intended application. Thanks Quote
the ber Posted December 4, 2011 Posted December 4, 2011 What exactly are you trying to do? Are you trying to draw a circle inside a square, or outside a square? Quote
mehrdad Posted December 4, 2011 Author Posted December 4, 2011 What exactly are you trying to do? Are you trying to draw a circle inside a square, or outside a square? Hello I want to start a drum circle is a square and an end to the widespread practice. Quote
mehrdad Posted December 4, 2011 Author Posted December 4, 2011 Hello I want to start a drum circle is a square and an end to the widespread practice. http://www.thesheetmetalshop.com/pdf_manual/Problem1.pdf Quote
ReMark Posted December 4, 2011 Posted December 4, 2011 I believe mehrdad wants to draw a transition piece like one would see in a HVAC system for instance. I guess he is looking to do this with programming. Couldn't it be done with LOFT command? Quote
mehrdad Posted December 4, 2011 Author Posted December 4, 2011 I believe mehrdad wants to draw a transition piece like one would see in a HVAC system for instance. I guess he is looking to do this with programming. Couldn't it be done with LOFT command? yes thanks Quote
fixo Posted December 4, 2011 Posted December 4, 2011 Try FAS file from second post in there: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Solid-Transitions/m-p/1564380/highlight/true#M204806 Unzip it then open new file only (Drawing1.dwg) Load fas file see command prompts, just tested it on A2009 it's working for me Quote
mehrdad Posted December 5, 2011 Author Posted December 5, 2011 I have a Visual Basic program for anyone who can help? http://www.thesheetmetalshop.com/pdf_manual/Problem1.pdf Quote
