discussing and explaining one lisp or help needed in understanding
I found this on http://www.afralisp.net/autolisp/tutorials/into-the-database.php AT THE BOTTOM OF PAGE
need help in digesting this.
(defun c:getlay ( / NAMES SIZ1)
;define funcion
(setvar "cmdecho" 0)
;switch off command echo
	(setq siz1 "0")
;initiliase variable
(setq userclick T)
;set flag
(setq f 1)
;rewind pointer
(while
;start while loop
	  (setq t1 (tblnext "Layer" f)) [color="blue"];; doen't really understand  what it means reseting f.[/color] HELP
  ;get the next layer
  (setq f nil)
  ;reset pointer
  (setq b (cdr (assoc 2 t1)))
  ;get the layer name
    (if (/= b "DEFPOINTS")
    ;if name is not equal to DEFPOINTS
       (setq NAMES (append NAMES (list b)))                      [color="blue"];;;up to know we have not define variable NAMES[/color] HELP
       ;Add the layer name to the list
    );if
);while
[color="silver"]	(setq dcl_id (load_dialog "getlay.dcl"))
;load dialogue
(if (not (new_dialog "getlay" dcl_id)
;check for errors
      );not
     (exit)
     ;if problem exit
);if
 (set_tile "sel1" "0")
 ;initilise list box
 (start_list "sel1")
 ;start the list
 (mapcar 'add_list NAMES)
 ;add the layer names
 (end_list)
 ;end the list
   (action_tile
   "cancel"
   "(done_dialog) (setq userclick nil)"
   );action_tile
   ;if cancel set flag to nil
 (action_tile
   "accept"
   (strcat
     "(progn
       (setq SIZ1 (get_tile \"sel1\"))"
      " (done_dialog)(setq userclick T))"
   );strcat
 );action tile
 ;if OK get the layer selected
 (start_dialog)
 (unload_dialog dcl_id)
  (if userclick
  ;if flag true
    (setq SIZ1 (nth (atoi SIZ1) NAMES))
    ;get the name of the layer from the list
    (alert (strcat "\nYou Selected Layer  " SIZ1))
    ;display the name
   );end progn
  );end if
);defun C:getlay
[/color]
  • Replies 21
  • Qonfire
    12
  • Lee Mac
    6
  • alanjt
    1
  • Lt Dan's legs
    1
Hello, this is a cylindrical hatch pattern
which code is responsable for hatch gradient color? i did change code 63. for smthg else but nothing happened graphically
((-1 . <Entity name: 7ef15f98>) (0 . "HATCH") (330 . <Entity name: 7ef06cf8>) (5 . "A49B") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbHatch") (10 0.0 0.0 0.0) (210 0.0 0.0 1.0) (2 . "SOLID") (70 . 1) (71 . 1) (91 . 1) (92 . 7) (72 . 0) (73 . 1) (93 . 4) (10 580.208 214.175 0.0) (10 512.05 214.175 0.0) (10 512.05 116.836 0.0) (10 580.208 116.836 0.0) (97 . 1) (330 . <Entity name: 7ef15fa0>) (75 . 0) (76 . 1) (47 . 0.396438) (98 . 1) (10 548.15 179.288 0.0) (450 . 1) (451 . 0) (460 . 0.0) (461 . 0.0) (452 . 1) (462 . 1.0) (453 . 2) (463 . 0.0) [color="red"](63 . 3)[/color] (421 . 16711680) (463 . 1.0) [color="red"]([color="red"]63 . [/color]7[/color]) (421 . 16777215) (470 . "CYLINDER"))
