wirty91 Posted December 5, 2011 Share Posted December 5, 2011 Hey, I have been trying to make this multileader but couldn't do it. And I don't know correct words how to google it. (See image below). You guys know how to do it? Quote Link to comment Share on other sites More sharing options...
Tiger Posted December 5, 2011 Share Posted December 5, 2011 I don't see any Leaders in your picture? DO you mean the height-indicators? edit: I moved your thread to a better suited part of the forum. Quote Link to comment Share on other sites More sharing options...
wirty91 Posted December 5, 2011 Author Share Posted December 5, 2011 I don't see any Leaders in your picture? DO you mean the height-indicators? Yeah, they are not mleaders? They are blocks? Or what? :s Quote Link to comment Share on other sites More sharing options...
Tiger Posted December 5, 2011 Share Posted December 5, 2011 I won't swear that they are not mleaders, I don't use them enough to make a permanent solution (I draw it when I need it) but I would perhaps suggest a dynamic block. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 5, 2011 Share Posted December 5, 2011 Those look more like a dimension style, wherein the extension lines have been suppressed on the lines tab, with an alternate arrow style specified from the arrow menu, or custom made. The plus sign can be added on the ALTERNATE DIMSTYLE tab, which is a pretty great place to get creative, eitheras a dimension prefix or suffix, above or below ... lots of fun to be had there. Decimal seperator set to ",". Quote Link to comment Share on other sites More sharing options...
wirty91 Posted December 5, 2011 Author Share Posted December 5, 2011 Those look more like a dimension style, wherein the extension lines have been suppressed on the lines tab, with an alternate arrow style specified from the arrow menu, or custom made. . But the building isn't 37meters tall, it's height from the ocean. So I can't just make dimensions with the building height. Quote Link to comment Share on other sites More sharing options...
Tiger Posted December 5, 2011 Share Posted December 5, 2011 But the building isn't 37meters tall, it's height from the ocean. So I can't just make dimensions with the building height. You can change the actual measurement to whatever you like - highlight a dimension, bring up Properties and find the Override-box. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 5, 2011 Share Posted December 5, 2011 But the building isn't 37meters tall, it's height from the ocean. So I can't just make dimensions with the building height. If you have never tried it before, you might like to give the QUICK PROPERTIES palette a go. Right click on its header, and you can customize the display to show you the exact information and options which you deem relevant. I live be it. Quote Link to comment Share on other sites More sharing options...
eldon Posted December 5, 2011 Share Posted December 5, 2011 Perhaps you might like to have a look at these two threads Thread1 Thread2 Read them all the way through, because the lisps, in the posts, get successively modified so the last one is best:D Quote Link to comment Share on other sites More sharing options...
wirty91 Posted December 5, 2011 Author Share Posted December 5, 2011 Perhaps you might like to have a look at these two threads Thread1 Thread2 Tried to fight with dimension styles and I didn't get right options. These two threads seems to be fine enough but I must first read something about LISPs. Thank you! Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted December 5, 2011 Share Posted December 5, 2011 I think your best bet would be a quick dynamic block. Quote Link to comment Share on other sites More sharing options...
Tankman Posted December 6, 2011 Share Posted December 6, 2011 I won't swear that they are not mleaders, I don't use them enough to make a permanent solution (I draw it when I need it) but I would perhaps suggest a dynamic block. I believe your triangle is part of the GD&T font. Quote Link to comment Share on other sites More sharing options...
