Question about scheduling
I want to see schedule of my hvac plans. It shows for example 400x400 ducts seperated by lengths. I checked settings but I couldnt find.
Have you set up an AEC Schedule in your Style Manager? There are pre-made templates that can get your started in the stock Template.
I created one but I couldnt just find it always shows it seperately .
If you open the Schedule Style, you'll notice there's a "Quantity" checkbox. Make sure that's checked.
if I put check to "Include Quantity Column" then it just put all of 300X300 duct which are 1000mm to one column but still there are still a lot of 300X300 mm duct is seen.
It shows same sizes seperately. I want to see just one total size of 400X400 mm ducts.
I don't think you can do that without heavy customization. It kind of defeats the purpose of scheduling the duct, although I do agree in our profession there should be more parameters OOTB that can obtain this data.
so need to write formula I guess.
I don't think you can do that. I think the only way you can do it is if you only select 400x400 mm duct that is in the same system, and even then you'll still need to quantify each piece for a "Total", giving you multiple rows of different length ducts. I've already been through this hassle years ago and never could find a solution, even with asking on multiple AutoCAD MEP forums.
