polarcreamsoda Posted December 8, 2011 Posted December 8, 2011 i have some renderings in rhino that i want to convert to CAD so i can take it to a laser cutter. is there a way to pull the planes from my rhino file over to CAD so i dont have to redraw the lines. they are curves so reproducing the lines would be alot of work if its not necessary. if you need more clarification on what needs to be done ask away. im pretty much a beginner with rhino so im kinda limited here. thanks! Quote
ReMark Posted December 8, 2011 Posted December 8, 2011 What file formats can Rhino save to or export? That's where I would start. Quote
SLW210 Posted December 8, 2011 Posted December 8, 2011 I thought AutoCAD 2012 could work with Rhino filkes. Model Documentation —Automatically generate intelligent documentation for AutoCAD, Autodesk® Inventor® software, and other models. You can import and document designs from a wide variety of software applications including SolidWorks®, Pro/ENGINEER®, CATIA®, Rhinoceros®, and NX®. Autodesk ® Inventor® Fusion —An easy-to-use tool for direct modeling, helping you flexibly edit and validate models from almost any source. I think Rhino can export to .dwg, .dxf, .fbx, .3ds, .dgn, .iges, .stl, .step and .sat among other files. What file type(s) does your laser cutter use? Quote
ReMark Posted December 8, 2011 Posted December 8, 2011 I wasn't aware of that SLW210. Thanks. I'll have to jot that down on my handy-dandy index card of important to stuff to remember. Quote
JD Mather Posted December 25, 2011 Posted December 25, 2011 I thought Rhino was CAD? Computer Aided Design Quote
