sparkyuk Posted December 8, 2011 Posted December 8, 2011 Hello All, once again I have received a drawing from a consultant that has not been drawn using Autocad i guess, once loaded if I try and copy and paste anything into the drawing autocad comes up with this warning "This application has detected a mixed version if AEC objects participating in thia operation, newer AEC objects will be disallowed from participating in this operation" Is there anything I can do please to sort this as cancelling everytime I paste anything is doing my head in. Quote
sparkyuk Posted December 8, 2011 Author Posted December 8, 2011 Thanks for the link but I can not see a AutoCAD 2008 version of object enabler there ? am i missing something ? Quote
CyberAngel Posted December 8, 2011 Posted December 8, 2011 On the first screen, select the flavor of AutoCAD you are using, I assume vanilla. On the next screen, scroll down to 2008 (your version). Select the enabler for the object type you need to view. I see Civil, Architectural, and Mechanical, for starters. Obviously, you'll need to know the type(s) of objects you're importing, that is, the flavor of AutoCAD that produced them. Or you could install all the enablers to make sure. Quote
sparkyuk Posted December 8, 2011 Author Posted December 8, 2011 Thanks M8 I went on to AutoCAD MEP 2008 Object Enabler and it said below so sorted just got to install and try I will come back tomorroer and let you know is its sorted AutoCAD MEP 2008 Object Enabler will enable objects in the following Autodesk products: AutoCAD 2008 AutoCAD LT 2008 AutoCAD Architecture 2008 AutoCAD Electrical 2008 AutoCAD Mechanical 2008 AutoCAD Map 3D 2008 Civil 3D 2008 Land Desktop 2008 Mechanical Desktop 2008 Quote
sparkyuk Posted December 9, 2011 Author Posted December 9, 2011 (edited) Well I am sorry to say that didnt cure it, One other thing I might have failed to tell you was when opening the drawing its comes up with a proxy information box and within it it says "Custom Objects created by ObjectARX application" and " to check if web for live enablers is selected in options box in the sytems tab" where is this sytems Tab please ? Edit found it under options sorry Things like Missing App AECScheuke60 and AECstructurebase60 are aslo in it ? Edited December 9, 2011 by sparkyuk Found Systems tab Quote
RobDraw Posted December 9, 2011 Posted December 9, 2011 It sounds like the file was created using a newer version of AutoCAD. If so, Drawing True View from AutoDesk will convert the drawing to a usable format for you. Quote
ReMark Posted December 9, 2011 Posted December 9, 2011 Re: Systems tab. This refers to your Options > Systems tab. There is a section on the right side with the heading "Live Enabler Options". Within that section is a checkoff box labeled "Check Web for Live Enablers". I'm not sure that's going to do much for you. Follow RobDraw's advice and see what happens. Report back here with the results. Quote
sparkyuk Posted December 9, 2011 Author Posted December 9, 2011 Well i have just downloaded True View and it will not install as it says my system is not SSE2 compliant, so it wont install, I am not having a lot of luck with this am I ? Could one of you nice gentleman let me have your email address via Pm and I will send this file to you so you can back save this to 2008 version please ? Quote
caddcop Posted December 9, 2011 Posted December 9, 2011 If the objects are from a newer version of AutoCAD, the only way to eliminate them is to open the file in that version, either with the original application or in the correct version of AutoCAD with the correct enablers and to then use the save as AutoCAD tool. That will explode the objects to primitive entities. True View does not allow enablers, so saving back with it will loose the objects and their graphics. If the file has proxy graphics drawn in it, True View can save it back and it will explode the proxy graphics or allow them to be exploded once the file is opened in AutoCAD. Also, it is possible for someone to open an older file with newer enablers and if they save the file, the objects are updated. When that occurs, the same process is required. Quote
RobDraw Posted December 9, 2011 Posted December 9, 2011 (edited) PM sent. I don't know what SSE2 compliant is but I seem to remember having trouble installing DTV on my 64 bit machine because of something to do with the .net framework. Edited December 9, 2011 by RobDraw Quote
SLW210 Posted December 9, 2011 Posted December 9, 2011 Why didn't you load ALL the Object Enablers? Quote
sparkyuk Posted December 9, 2011 Author Posted December 9, 2011 Why didn't you load ALL the Object Enablers? I didnt think they would work on autocad 2008, as the other enablers were not for it am I wrong ? Quote
sparkyuk Posted December 9, 2011 Author Posted December 9, 2011 Well thanks to RobDraw who has saved it back to 2007 for me, it still opens with ""Custom Objects created by ObjectARX application" pop up But the "This application has detected a mixed version if AEC objects participating in this operation, newer AEC objects will be disallowed from participating in this operation" has gone and it works fine. So unless someone knows a cure for "Custom Objects created by ObjectARX application" pop up, I can live with it as it only happens once when opening the drawing. Thanks again Rob m8 Quote
SLW210 Posted December 9, 2011 Posted December 9, 2011 I didnt think they would work on autocad 2008, as the other enablers were not for it am I wrong ? All of them listed for AutoCAD 2008 are for AutoCAD 2008. Utilities & Drivers AutoCAD® 2008 MDI Tabs Update for AutoCAD AutoCAD Civil 2008 Object Enabler Regapp ID Cleanup Utility Rotating Attributes Hotfix Scale List Cleanup Utility AutoCAD MEP 2008 Object Enabler AutoCAD Architecture 2008 Object Enabler Advanced Configuration Guide for Autodesk Data Management Server 2008 AutoCAD MEP 2008 DACH Object Enabler (German Only) Autodesk Vault Autoloader 2008 AutoCAD DWFx Driver AutoCAD Raster Design 2008 Object Enabler Autodesk Mechanical Desktop 2008 Object Enabler Autodesk 3DSOUT Command Quote
