frula239 Posted December 8, 2011 Posted December 8, 2011 example this is my custom toolbar and how i can save this and export to another computer... i use autoCAD 2007 thanks Quote
SLW210 Posted December 8, 2011 Posted December 8, 2011 I do not see any image, try loading it directly to CADTutor with "Go Advanced" then "Manage Attachments". Quote
ReMark Posted December 8, 2011 Posted December 8, 2011 I answered a similar question yesterday. I'll see if I can find it for you. I'll be back. Here you go...http://www.cadtutor.net/forum/showthread.php?64904-Copping-Blocks-In-Tool-Palettes-From-One-Machine-To-Another&highlight=stockton Quote
BIGAL Posted December 9, 2011 Posted December 9, 2011 The other way is to save your toolbar as a partial menu then just use menuload this keeps them independant of the master CUI You can export it out of a cui or else just use notepad and create from scratch eg ***MENUGROUP=ALANSTOOLBAR ***TOOLBARS **ALANSTOOLS ID_TbModify [_Toolbar("Alans", _Right, _Show, 0, 0, 1)] AECC_ShowTS [_Button("Show Toolspace", RCDATA_16_IMAGE, RCDATA_16_IMAGE)]^C^C^C^P_ShowTS ID_Matchprop [_Button("Match Properties", RCDATA_16_MATCH, RCDATA_16_MATCH)]^C^C_matchprop ID_Erase [_Button("Erase", RCDATA_16_ERASE, RCDATA_32_ERASE)]^C^C_erase ID_Copy [_Button("Copy", RCDATA_16_COPYOB, RCDATA_32_COPYOB)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_copy,^C^C_copy) ID_Mirror [_Button("Mirror", RCDATA_16_MIRROR, RCDATA_32_MIRROR)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_mirror,^C^C_mirror) ID_Offset [_Button("Offset", RCDATA_16_OFFSET, RCDATA_32_OFFSET)]^C^C_offset ID_Array [_Button("Array...", RCDATA_16_ARRREC, RCDATA_32_ARRREC)]^C^C_array ID_Move [_Button("Move", RCDATA_16_MOVE, RCDATA_32_MOVE)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_move,^C^C_move) ID_Rotate [_Button("Rotate", RCDATA_16_ROTATE, RCDATA_32_ROTATE)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_rotate,^C^C_rotate) ID_Scale [_Button("Scale", RCDATA_16_SCALE, RCDATA_32_SCALE)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_scale,^C^C_scale) ID_Stretch [_Button("Stretch", RCDATA_16_STRETC, RCDATA_32_STRETC)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_stretch,^C^C_stretch) ID_Trim [_Button("Trim", RCDATA_16_TRIM, RCDATA_32_TRIM)]^C^C_trim ID_Extend [_Button("Extend", RCDATA_16_EXTEND, RCDATA_32_EXTEND)]^C^C_extend ID_BreakSele [_Button("Break at Point", RCDATA_16_BREAKATPT, RCDATA_32_BREAKATPT)]^C^C_break \_f \@ ID_Break [_Button("Break", RCDATA_16_BRE2PT, RCDATA_32_BRE2PT)]^C^C_break ID_Join [_Button("Join", RCDATA_16_JOIN, RCDATA_32_JOIN)]^C^C_join ID_Chamfer [_Button("Chamfer", RCDATA_16_CHAMFE, RCDATA_32_CHAMFE)]^C^C_chamfer ID_Fillet [_Button("Fillet", RCDATA_16_FILLET, RCDATA_32_FILLET)]^C^C_fillet ID_Explode [_Button("Explode", RCDATA_16_EXPLODE, RCDATA_32_EXPLODE)]^C^C_explode ID_LAYFRZ [_Button("Layer, Layer Freeze", RCDATA_16_FRZLAY, RCDATA_32_FRZLAY)]^C^C_layfrz ID_LAYOFF [_Button("Layer Off", RCDATA_16_OFFLAY, RCDATA_32_OFFLAY)]^C^C_layoff ID_LAYISO [_Button("Layer Isolate", RCDATA_16_LAYISO,RCDATA_32_LAYISO)]^C^C_layiso MM_LAYUNISO [_Button("Layer Unisolate", RCDATA_16_LAYUNISO, RCDATA_32_LAYUNISO)]^C^C_Layuniso ID_LAYDEL [_Button("Layer, Layer Delete", RCDATA_16_LAYER_DELETE,RCDATA_32_LAYER_DELETE)]^C^C_laydel ID_Line [_Button("Line", RCDATA_16_LINE,RCDATA_32_LINE)]^C^C_line MM_1608 [_Button("Circle", RCDATA_16_CIRRAD,RCDATA_32_CIRRAD)]^C^C_circle MM_1607 [_Button("Arc", RCDATA_16_ARC3PT,RCDATA_32_ARC3PT)]^C^C_arc ID_Pline [_Button("Polyline", RCDATA_16_PLINE,RCDATA_32_PLINE)]^C^C_pline ID_Pedit [_Button("Polyline Edit", RCDATA_16_PEDIT, RCDATA_32_PEDIT)]^C^C_pedit ID_DrawordeB [_Button("Draw Order, Send to Back", RCDATA_16_SN2BCK,RCDATA_32_SN2BCK)]^C^C^P_ai_draworder _Back ^P ID_Appload [_Button("Load Application...", RCDATA_16_LOAD_APPLICATIONS,RCDATA_16_LOAD_APPLICATIONS)]^C^C_appload Quote
