Jon McElwain Posted December 8, 2011 Posted December 8, 2011 I am building a block with some attribute text and I need to be able to backmask the text. The properties menu does not have a backmask option for the text attribute when I open the block in the block editor. I am using Autocad LT 2011 Thanks for the help!! Quote
Jon McElwain Posted December 9, 2011 Author Posted December 9, 2011 Okay, I got the backmask to work - it turns out you have to use multiline text, then, while editing the text, you can right-click and select background mask from the drop down menu. Only problem is, I can not keep the backmasked text to stay behind the rest of the block. I attached a copy of the block - it is super simple, but I can not get the backmask to work! As always, thanks for the help. FCD STANDARD DRAWINGS.dwg Quote
