Toolbox - Changing values
ctapia1311
Hi Guys...
I would like to know if is it possible to change or add a configuration of the SoliWorks Toolbox.
For example if I set a Socket Head Cap Screw M4 in de Design Library and I need a lenght larger than the maximum (40mm). What can I do??? Is it possible to modify this values for different ones according to the needs?
Thanks on beforehand for your comments
Yes you can by editing the definition. You can also add your own smart components to the toolbox. Search your help for "add to library" to see how to add your own components. I believe if you just try to drag/drop a toolbox component into a part file(not assembly) it will open and you can make your changes and save it.
