VBA list sort function help/guidance
Hi vba gurus
How do you sort a list in vba so that the list is a-z no matter of capitals or lower case EG A-a-B-b-C-c-D-d etc
Also can you sort the list so that if it is a number it is at the start of the list
eg 0,1,2,3,4,5,6,7,8,9,A,a,B,b,C,c,D,d,E,e,........Z,z
Thanks guys:D
Cheers - i'll read now.
Thanks
I found one already done posted on a different site - i thought it might be useful to others so i'll post it here
The below code will sort a list box - wether it has 1,2,3 etc columns
[color=#0000ff]Sub[/color] SortListBox(oLb [color=#0000ff]As[/color] MSForms.ListBox, sCol [color=#0000ff]As[/color] [color=#0000ff]Integer[/color], sType [color=#0000ff]As[/color] [color=#0000ff]Integer[/color], sDir [color=#0000ff]As[/color] [color=#0000ff]Integer[/color])
   [color=#0000ff]Dim[/color] vaItems [color=#0000ff]As[/color] [color=#0000ff]Variant[/color]
   [color=#0000ff]Dim[/color] i [color=#0000ff]As[/color] [color=#0000ff]Long[/color], j [color=#0000ff]As[/color] [color=#0000ff]Long[/color]
   [color=#0000ff]Dim[/color] c [color=#0000ff]As[/color] [color=#0000ff]Integer[/color]
   [color=#0000ff]Dim[/color] vTemp [color=#0000ff]As[/color] [color=#0000ff]Variant[/color]
    [color=#006400]'Put the items in a variant array[/color]
   vaItems = oLb.List
    [color=#006400]'Sort the Array Alphabetically(1)[/color]
   [color=#0000ff]If[/color] sType = 1 [color=#0000ff]Then[/color]
       [color=#0000ff]For[/color] i = [color=#0000ff]LBound[/color](vaItems, 1) [color=#0000ff]To[/color] [color=#0000ff]UBound[/color](vaItems, 1) - 1
           [color=#0000ff]For[/color] j = i + 1 [color=#0000ff]To[/color] [color=#0000ff]UBound[/color](vaItems, 1)
                [color=#006400]'Sort Ascending (1)[/color]
               [color=#0000ff]If[/color] sDir = 1 [color=#0000ff]Then[/color]
                   [color=#0000ff]If[/color] vaItems(i, sCol) > vaItems(j, sCol) [color=#0000ff]Then[/color]
                       [color=#0000ff]For[/color] c = 0 [color=#0000ff]To[/color] oLb.ColumnCount - 1 [color=#006400]'Allows sorting of multi-column ListBoxes[/color]
                           vTemp = vaItems(i, c)
                           vaItems(i, c) = vaItems(j, c)
                           vaItems(j, c) = vTemp
                       [color=#0000ff]Next[/color] c
                   [color=#0000ff]End[/color] [color=#0000ff]If[/color]
                    [color=#006400]'Sort Descending (2)[/color]
               [color=#0000ff]ElseIf[/color] sDir = 2 [color=#0000ff]Then[/color]
                   [color=#0000ff]If[/color] vaItems(i, sCol) < vaItems(j, sCol) [color=#0000ff]Then[/color]
           [color=#0000ff]Next[/color] j
       [color=#0000ff]Next[/color] i
        [color=#006400]'Sort the Array Numerically(2)[/color]
        [color=#006400]'(Substitute CInt with another conversion type (CLng, CDec, etc.) depending on type of numbers in the column)[/color]
   [color=#0000ff]ElseIf[/color] sType = 2 [color=#0000ff]Then[/color]
                   [color=#0000ff]If[/color] [color=#0000ff]CInt[/color](vaItems(i, sCol)) > [color=#0000ff]CInt[/color](vaItems(j, sCol)) [color=#0000ff]Then[/color]
                   [color=#0000ff]If[/color] [color=#0000ff]CInt[/color](vaItems(i, sCol)) < [color=#0000ff]CInt[/color](vaItems(j, sCol)) [color=#0000ff]Then[/color]
    [color=#006400]'Set the list to the array[/color]
   oLb.List = vaItems
[color=#0000ff]End Sub[/color]
You can call the code by using the below.
To sort listbox1 for example just call the below in a sub
 'Sort by the 1st column in the ListBox Alphabetically in Ascending Order
SortListBox ListBox1, 0, 1, 1
'Sort by the 1st column in the ListBox Alphabetically in Descending Order
SortListBox ListBox1, 0, 1, 2
'Sort by the 2nd column in the ListBox Numerically in Ascending Order
SortListBox ListBox1, 1, 2, 1
'Sort by the 2nd column in the ListBox Numerically in Descending Order
SortListBox ListBox1, 1, 2, 2
