Self Intersecting Surface while Sweeping
Hi
New here, never posted in one of these... Ever
I am trying to create a CAD drawing for the construction of Paddle Pop sticks. It is the basic shape of the Magnum sticks, but it is tricky because it has a 140 diameter taper, from the top of the jig to the bottom. I am trying to make the circle attached to the shape of the stick, and the Sweep the circle around the shape. But when I try to sweep it around, it says "The sweep results in a self-intersecting circle". I am using AutoCAD 2012.
Any help on this would be greatly appreciated.
Thanks!
Mick
P.S. I have attached the .dwg file so that it makes more sense.
Austicks Magnum Paddle Pop Stick.dwg
I managed to sweep a circle based upon an approximation of the shape you provided. Here is the result.
Edited by ReMark
I'm assuming you figured out a solution all on your own thus the reason for no reply. Good for you.
More power to you if you got it by yourself. Self intersecting surfaces are a real PITA. While trying to analyze and rectify the sweeping issue, a rrhoid pillow could come in handy. Butt all kidding aside, well done ReMark, I tried and couldn't do it. I'm guessing that you swept it as short little bits. I was trying to sweep the whole as a polyline, and came up short (hey, that's what she said!).
