Engagement Lenght MVparts
I can't seem to get this to work right. Not sure what I am missing. If I leave the engagement length 0 the connectors are at the end of the valve and look right but the pipe in the properties box only shows the pipe length, not the pipe length plus engagement. If I set the engagement to 1" Then the pipe ends up longer than what it is supposed to be plus engagement. Hope you can put me on the right path.
Thanks
I finally figured out what I was doing wrong. When I was placing the connector and then the normal direction I was clicking out in a random spot. When I started entering (1) unit in the direction I wanted everything worked as it should.
