MMS Posted December 14, 2011 Posted December 14, 2011 Could some explain me how to extract data from ACAD table. I have try dump object but can't find the data. I wanna see structure data for join table. ; IAcadTable: IAcadTable Interface ; Property values: ; AllowManualHeights = 0 ; AllowManualPositions = 0 ; Application (RO) = #<VLA-OBJECT IAcadApplication 00d5f1d4> ; BreaksEnabled = 0 ; BreakSpacing = 0.99 ; Columns = 6 ; ColumnWidth (RO) = ...Indexed contents not shown... ; Direction = (1.0 0.0 0.0) ; Document (RO) = #<VLA-OBJECT IAcadDocument 02b6de18> ; EnableBreak (RO) = ...Indexed contents not shown... ; FlowDirection = 1 ; Handle (RO) = "ACB1F" ; HasExtensionDictionary (RO) = 0 ; HasSubSelection (RO) = 0 ; HeaderSuppressed = -1 ; Height = 4.12 ; HorzCellMargin = 3.0 ; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 2331417c> ; InsertionPoint = (-1393.84 128.008 0.0) ; Layer = "Construction Line" ; Linetype = "ByLayer" ; LinetypeScale = 3.0 ; Lineweight = -1 ; Material = "ByLayer" ; MinimumTableHeight (RO) = 4.12 ; MinimumTableWidth (RO) = 54.0 ; ObjectID (RO) = 2082178808 ; ObjectName (RO) = "AcDbTable" ; OwnerID (RO) = 2043363520 ; PlotStyleName = "ByLayer" ; RegenerateTableSuppressed = 0 ; RepeatBottomLabels = 0 ; RepeatTopLabels = 0 ; RowHeight (RO) = ...Indexed contents not shown... ; Rows = 1 ; StyleName = "Standard" ; TableBreakFlowDirection = 1 ; TableBreakHeight = 0.0 ; TableStyleOverrides (RO) = (2) ; TitleSuppressed = 0 ; TrueColor = #<VLA-OBJECT IAcadAcCmColor 1f2df440> ; VertCellMargin = 0.06 ; Visible = -1 ; Width = 259.2 Thanks, UdaAf Quote
irneb Posted December 14, 2011 Posted December 14, 2011 Are you looking for the values inside the cells? If so look at my code in this thread: http://forums.augi.com/showthread.php?t=135274 Strange how similar questions come up close together BTW, to modify the table you need its methods as well. vlax-dump-object only shows these if you send it a non-nil 2nd argument as well. Quote
Lee Mac Posted December 15, 2011 Posted December 15, 2011 To build on Irneb's suggestions, use: (vlax-dump-object <VLA-Object> t) to display all methods associated with the object, in addition to the properties. To retrieve cell values, study the GetText / GetCellValue / GetValue methods. Lee Quote
MMS Posted December 16, 2011 Author Posted December 16, 2011 Thanks All for your answer. I will try . Thanks, UdaAf Quote
MMS Posted December 17, 2011 Author Posted December 17, 2011 Please advice for my code. I think algorithm is correct but still can't get value from table. (defun c:jontab () (vl-load-com) (setq TblSel (car (entsel "\nPilih Table Utama:")) TblObj (vlax-ename->vla-object TblSel) Columns_1 (vla-get-columns TblObj) Rows_1 (vla-get-rows TblObj) ) ;Membuat List Kosong Untuk Mengumpulkan Data (setq TblValList_1 '()) (setq row 0 column 0 ) (repeat Rows_1 (repeat Columns_1 (setq TblVal (vla-gettext TblObj row column) TblValList_1 (cons TblVal TblValList_) column (1+ column) ) ;setq ) ;repeat (setq row (1+ row) column 1 ) ;reset column menjadi 1 ) ;repeat );defun Thanks, UdaAf Quote
Lee Mac Posted December 17, 2011 Posted December 17, 2011 Try this, quickly written, but the returned list format in matrix form seems more intuitive to me: (defun c:jontab ( / i j l o r s ) (if (setq s (ssget "_+.:E:S" '((0 . "ACAD_TABLE")))) (progn (setq o (vlax-ename->vla-object (ssname s 0))) (repeat (setq i (vla-get-rows o)) (setq i (1- i)) (repeat (setq j (vla-get-columns o)) (setq j (1- j) l (cons (vla-gettext o i j) l)) ) (setq r (cons l r) l nil ) ) r ) ) ) (vl-load-com) Quote
MMS Posted December 18, 2011 Author Posted December 18, 2011 Hi Lee, Nice code lee . I will improve this code for join 2 table or more. Thanks, UdaAf Quote
MMS Posted December 21, 2011 Author Posted December 21, 2011 Hi Lee, Please advice for this code. I think my code is wrong at L00035. If I choose table with row qty 1 it's no problem. But if I choose row with qty > 1 the last row don't have field. Here's the code ; (defun c:jontab (/ i j l o r s s2 o2 rq ir rdat ic ) (princ "\nPilih Table Yang Akan dipindah:") (if (setq s (ssget "_+.:E:S" '((0 . "ACAD_TABLE")))) (progn (setq o (vlax-ename->vla-object (ssname s 0))) (repeat (setq i (vla-get-rows o)) (setq i (1- i)) (repeat (setq j (vla-get-columns o)) (setq j (1- j) l (cons (vla-gettext o i j) l) ) ) ;repeat (setq r (cons l r) l nil ) ;setq ) ;repeat r ) ;progn ) ;if ;memindahkan table ke table tujuan (princ "\nPilih Table Tujuan:") (setq ic 0) (if (setq s2 (ssget "_+.:E:S" '((0 . "ACAD_TABLE")))) (progn (setq o2 (vlax-ename->vla-object (ssname s2 0))) ;meng-insert row berdasarkan jumlah row pada table terpilih (repeat (setq rq (vla-get-rows o)) (vla-insertrows o2 (1+ rq) (vla-GetRowHeight o 0) 1) ;setting incremental dan mengambil data masing-masing table (setq ir 0 rdat (nth ir r) ) (repeat (length rdat) ;L00035 Wrong Algorithm [color=red](vla-settext o2 (- (vla-get-rows o2) 1) ic (nth ic rdat)) ;vla-settext[/color] (setq ic (1+ ic)) ) ;repeat (setq ir (1+ ir)) ) ;repeat ) ;progn ) ;if ) (vl-load-com) Quote
Lee Mac Posted December 21, 2011 Posted December 21, 2011 Try something like this: [color=GREEN];; Merge Tables - Lee Mac - www.lee-mac.com[/color] ([color=BLUE]defun[/color] c:MergeTables ( [color=BLUE]/[/color] *error* _entsel acdoc c c2 i j l r r2 t1 t2 x y ) ([color=BLUE]defun[/color] *error* ( msg ) ([color=BLUE]if[/color] acdoc ([color=BLUE]vla-endundomark[/color] acdoc)) ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]wcmatch[/color] ([color=BLUE]strcase[/color] msg) [color=MAROON]"*BREAK,*CANCEL*,*EXIT*"[/color])) ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nError: "[/color] msg)) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]defun[/color] _entsel ( msg filter [color=BLUE]/[/color] sel ) ([color=BLUE]princ[/color] msg) ([color=BLUE]setvar[/color] 'NOMUTT 1) ([color=BLUE]setq[/color] sel ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]ssget[/color] ([color=BLUE]list[/color] [color=MAROON]"_+.:E:S:L"[/color] filter))) ([color=BLUE]setvar[/color] 'NOMUTT 0) ([color=BLUE]if[/color] ([color=BLUE]and[/color] sel ([color=BLUE]not[/color] ([color=BLUE]vl-catch-all-error-p[/color] sel))) ([color=BLUE]ssname[/color] sel 0) ) ) ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] t1 (_entsel [color=MAROON]"\nSelect Table to Merge: "[/color] '((0 . [color=MAROON]"ACAD_TABLE"[/color])))) ([color=BLUE]setq[/color] t2 (_entsel [color=MAROON]"\nSelect Table to Merge With: "[/color] '((0 . [color=MAROON]"ACAD_TABLE"[/color])))) ) ([color=BLUE]progn[/color] ([color=BLUE]setq[/color] acdoc ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))) ([color=BLUE]vla-startundomark[/color] acdoc) ([color=BLUE]setq[/color] t1 ([color=BLUE]vlax-ename->vla-object[/color] t1) t2 ([color=BLUE]vlax-ename->vla-object[/color] t2) ) ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]vla-get-rows[/color] t1)) ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i)) ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] j ([color=BLUE]vla-get-columns[/color] t1)) ([color=BLUE]setq[/color] j ([color=BLUE]1-[/color] j) l ([color=BLUE]cons[/color] ([color=BLUE]vla-gettext[/color] t1 i j) l)) ) ([color=BLUE]setq[/color] r ([color=BLUE]cons[/color] l r) l [color=BLUE]nil[/color] ) ) ([color=BLUE]setq[/color] c2 ([color=BLUE]vla-get-columns[/color] t2) r2 ([color=BLUE]vla-get-rows[/color] t2) ) ([color=BLUE]if[/color] ([color=BLUE]<[/color] 0 ([color=BLUE]setq[/color] c ([color=BLUE]-[/color] ([color=BLUE]length[/color] ([color=BLUE]car[/color] r)) c2))) ([color=BLUE]vla-insertcolumns[/color] t2 c2 ([color=BLUE]vla-getcolumnwidth[/color] t2 ([color=BLUE]1-[/color] c2)) c) ) ([color=BLUE]vla-insertrows[/color] t2 r2 ([color=BLUE]vla-getrowheight[/color] t2 ([color=BLUE]1-[/color] r2)) ([color=BLUE]length[/color] r)) ([color=BLUE]setq[/color] i r2) ([color=BLUE]while[/color] ([color=BLUE]setq[/color] x ([color=BLUE]car[/color] r)) ([color=BLUE]setq[/color] j 0) ([color=BLUE]while[/color] ([color=BLUE]setq[/color] y ([color=BLUE]car[/color] x)) ([color=BLUE]vla-settext[/color] t2 i j y) ([color=BLUE]setq[/color] x ([color=BLUE]cdr[/color] x) j ([color=BLUE]1+[/color] j) ) ) ([color=BLUE]setq[/color] r ([color=BLUE]cdr[/color] r) i ([color=BLUE]1+[/color] i) ) ) ([color=BLUE]vla-delete[/color] t1) ([color=BLUE]vla-endundomark[/color] acdoc) ) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) Quote
MMS Posted December 21, 2011 Author Posted December 21, 2011 Hi lee thanks . But can you advice for my code. Thanks, UdaAf Quote
Lee Mac Posted December 22, 2011 Posted December 22, 2011 Hi lee thanks .But can you advice for my code. Maybe you can identify your problem from studying my code Quote
MMS Posted December 22, 2011 Author Posted December 22, 2011 Maybe you can identify your problem from studying my code Owkay la lee . Thanks for your advice Quote
