open dwg , modify and save as
HI
I have to open all dwg in a directory, modify some block attribute ( like BOM..drawng number..) and make a saveas.
Fist i make the code for a already opened dwg, modifiy it and saveas ( with
mydwg.CloseAndSave(ligneF) )
All work greet, a soon i put it in a loop to open all dwg. autocad crash when i saveas the file.
can you help me. I try to option , with readdwgfile, and
Application.DocumentManager.Open . I have the same error on both way.
ps 1, if i run only the open, and saveas line, i have the same error too.
thanks' for your help
this is my code
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] fichiersTrouv = Directory.GetFiles(T_CIBLE.Text, [/size][size=2][color=#a31515][size=2][color=#a31515]"*.dwg"[/color][/size][/color][/size][size=2], SearchOption.AllDirectories)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]For[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Each[/color][/size][/color][/size][size=2] ligneF [/size][size=2][color=#0000ff][size=2][color=#0000ff]In[/color][/size][/color][/size][size=2] fichiersTrouv [/size][size=2][color=#008000][size=2][color=#008000]' the list of file is correct[/color][/size]
[/color][/size][size=2][color=#008000][size=2][color=#008000]'Application.DocumentManager.Open option[/color][/size]
[/color][/size][size=2][color=#008000][size=2][color=#008000]'Dim mydwg As Document = Application.DocumentManager.Open(ligneF)[/color][/size]
[/color][/size][size=2][color=#008000][size=2][color=#008000]' Dim myDWG As Document = Application.DocumentManager.MdiActiveDocument[/color][/size]
[/color][/size][size=2][color=#008000][size=2][color=#008000]' myDB = myDWG.Database[/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myDB [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] Database([/size][size=2][color=#0000ff][size=2][color=#0000ff]False[/color][/size][/color][/size][size=2], [/size][size=2][color=#0000ff][size=2][color=#0000ff]True[/color][/size][/color][/size][size=2])[/size]
[size=2]myDB.ReadDwgFile(ligneF, IO.FileShare.ReadWrite, [/size][size=2][color=#0000ff][size=2][color=#0000ff]True[/color][/size][/color][/size][size=2], [/size][size=2][color=#a31515][size=2][color=#a31515]""[/color][/size][/color][/size][size=2])[/size]
[size=2][color=#008000][size=2][color=#008000]' this section have no error, it work alone[/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Using[/color][/size][/color][/size][size=2] mytrans [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Transaction = myDB.TransactionManager.StartTransaction[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]For[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Each[/color][/size][/color][/size][size=2] myBlockName [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]String[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]In[/color][/size][/color][/size][size=2] GetTopLevelBlocks(myDB)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]For[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Each[/color][/size][/color][/size][size=2] BRefID [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] ObjectId [/size][size=2][color=#0000ff][size=2][color=#0000ff]In[/color][/size][/color][/size][size=2] GetBRefIDs(myDB, myBlockName)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size][/color][/size][size=2] myBlockName = [/size][size=2][color=#a31515][size=2][color=#a31515]"DANCART"[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Then[/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] MYATTVALS [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] Dictionary([/size][size=2][color=#0000ff][size=2][color=#0000ff]Of[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]String[/color][/size][/color][/size][size=2], [/size][size=2][color=#0000ff][size=2][color=#0000ff]String[/color][/size][/color][/size][size=2])[/size]
[size=2]MYATTVALS.Add([/size][size=2][color=#a31515][size=2][color=#a31515]"PROJET"[/color][/size][/color][/size][size=2], [/size][size=2][color=#a31515][size=2][color=#a31515]"A"[/color][/size][/color][/size][size=2])[/size]
[size=2]MYATTVALS.Add([/size][size=2][color=#a31515][size=2][color=#a31515]"CLIENT1"[/color][/size][/color][/size][size=2], [/size][size=2][color=#a31515][size=2][color=#a31515]"B"[/color][/size][/color][/size][size=2])[/size]
[size=2]MYATTVALS.Add([/size][size=2][color=#a31515][size=2][color=#a31515]"CLIENT2"[/color][/size][/color][/size][size=2], [/size][size=2][color=#a31515][size=2][color=#a31515]"C"[/color][/size][/color][/size][size=2])[/size]
[size=2]MYATTVALS.Add([/size][size=2][color=#a31515][size=2][color=#a31515]"DESSINATEUR"[/color][/size][/color][/size][size=2], [/size][size=2][color=#a31515][size=2][color=#a31515]"D"[/color][/size][/color][/size][size=2])[/size]
[size=2]MYATTVALS.Add([/size][size=2][color=#a31515][size=2][color=#a31515]"DATE"[/color][/size][/color][/size][size=2], [/size][size=2][color=#a31515][size=2][color=#a31515]"E"[/color][/size][/color][/size][size=2])[/size]
[size=2]MYATTVALS.Add([/size][size=2][color=#a31515][size=2][color=#a31515]"DESSIN"[/color][/size][/color][/size][size=2], [/size][size=2][color=#a31515][size=2][color=#a31515]"F"[/color][/size][/color][/size][size=2])[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Using[/color][/size][/color][/size][size=2] myTrans2 [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Transaction = BRefID.Database.TransactionManager.StartTransaction[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myBRef [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] BlockReference = BRefID.GetObject(OpenMode.ForRead)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myAttCollection [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] AttributeCollection = myBRef.AttributeCollection[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]For[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Each[/color][/size][/color][/size][size=2] myAttRefID [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] ObjectId [/size][size=2][color=#0000ff][size=2][color=#0000ff]In[/color][/size][/color][/size][size=2] myAttCollection[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myAttRef [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] AttributeReference = myAttRefID.GetObject(OpenMode.ForWrite)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size][/color][/size][size=2] MYATTVALS.ContainsKey(myAttRef.Tag) [/size][size=2][color=#0000ff][size=2][color=#0000ff]Then[/color][/size]
[/color][/size][size=2]myAttRef.TextString = MYATTVALS(myAttRef.Tag)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Next[/color][/size]
[/color][/size][size=2]myTrans2.Commit()[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Using[/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size]
[/color][/size][size=2]mytrans.Commit()[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Using[/color][/size][/color][/size]
[/color][/size][size=2]myDB.SaveAs(ligneF & [/size][size=2][color=#a31515][size=2][color=#a31515]"1.dwg"[/color][/size][/color][/size][size=2], DwgVersion.AC1004) [/size][size=2][color=#008000][size=2][color=#008000]' crash on this line[/color][/size]
[/color][/size][size=2]myDB.Dispose()[/size]
[size=2][color=#008000][size=2][color=#008000]' mydwg.CloseAndSave(ligneF) 'Application.DocumentManager.Open option crash [/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Sub[/color][/size]
[/color][/size]
Use Try ... Catch statement to get descriptive error message
Something like
Try
...your code goes here
Catch ex as AutoDesk.Autocad.Runtime.Exception ''/*or System.Exception*/
Application.ShowAlertDialog(ex.Message + vblf + ex.StackTrace
Finally
'keep it blank yet
End Try
Next use namespace System.IO to get valid fullpath,
probably you had missed a backslash in this line:
Imports System.IO
myDB.SaveAs(Path.Combine(ligneF, "1.dwg"), DwgVersion.AC1004)
Then (I don't know your current version) perhaps,
you have to pass 3 arguments instead of two to this method:
myDB.SaveAs(Path.Combine(ligneF, "1.dwg"), DwgVersion.AC1004,DataBase.SecurityParameters)
Would be good to use
Using ... End Using statement for myDB object
Just on the quick glance
THANKS'
I use the TRY..CATCH and i found that i use the wrong dwgversion with the MYDB.SAVEAS command
The sSAVEAS work well now
I try the MYDB.SAVE() command but it don't work ???
the TRY CATCH give me a eFileINternalErr
bizzard
  • 2 weeks later...
thank's for your help. I see somewhere that only the SAVEAS work, to keep the integrity of the database.
SO, i saveas, delete the old file, rename the new file
