jquackenbush Posted December 15, 2011 Posted December 15, 2011 I use a lot of PDF and Raster images to help reference, now I have two different PDFs that are over lapped. Is there a way to make the top PDF say 50% transparent so I can see both at the same time? Quote
SLW210 Posted December 15, 2011 Posted December 15, 2011 Select then Right-Click>Properties>Fade you can set from 0 (no fade) to 90 Quote
jquackenbush Posted December 15, 2011 Author Posted December 15, 2011 That will only fade the PDF, it does not allow me to see through it. I would like to be able to see the PDF on the bottom layer as well Quote
SLW210 Posted December 15, 2011 Posted December 15, 2011 It works here on 2011. Can you post your file? Quote
wlcmhm Posted December 15, 2011 Posted December 15, 2011 Have you tried the clip command (possibly imageclip) for the overlap areas? that would remove anything from being on bottom assuming the overlap in pdf shows the needed material on both pdfs where you could just clip one. Quote
