After re installing auto cad 2006 any dcl files are not working.sample file and error message in acad .dce file is as follows
LINK1 : dialog {
***** *** label = "    test";
****** ** : column {
****** ** * : boxed_column {
: radio_column* {
***** *********** key = "radios";
label = "cadgroup";
****** ****** : edit_box {
****** ******** key = "scale";
****** ******** label = "Scale:";
               edit_width = 3;
               value = "40";
         ***** initial_focus = true;
: edit_box {
****** ******** key = "type";
****** ******** label = "Bar Type:";
               edit_width = 1;
               value = "R";
* : edit_box {
****** ******** key = "dia";
****** ******** label = "Bar Dia.:";
               edit_width = 2;
               value = "6";
******: edit_box {
****** ******** key = "mark";
****** ******** label = "Bar Mark:";
               edit_width = 3;
               value = "01";
: edit_box {
****** ******** key = "spacing";
****** ******** label = "Bar Spacing:";
               edit_width = 3;
               value = "200";
****** ** * : boxed_row {
label = "ww";
             : button {
               key = "accept";
               label = "  Okay  ";
               is_default = true;
             : button {
               key = "cancel";
               label = "Cancel";
               is_default = false;
               is_cancel = true;
====== DCL semantic audit of C:/Program Files/AutoCAD 2006/$vld$.dcl ======
Error. Widget named "default_dcl_settings" is undefined.
Error in "LINK1". (widget type = ** undefined **, key = "")
   Widgets of this type cannot have children.
Let try to clean all **** char in DCL code file
There was no chars (stars) in original file . it was generated after Wrap code of the Forum. original file attached.
66.DCL
Hello Wimal!
I looked at the dcl file but I couldn´t find anything that should result in an error.
If you want to copy-paste, put the dcl code in c:\temp\66.dcl (the lisp code can be where ever you want).
DCL code:
LINK1 : dialog {
 label = "    test";
 : column {
   : boxed_column {
     : radio_column  {
       key = "radios";
       label = "cadgroup";
     : edit_box {
       key = "scale";
       label = "Scale:";
       edit_width = 3;
       value = "40";
       initial_focus = true; //All other focus attributes has been taken away with comment.
     : edit_box {
       key = "type";
       edit_width = 1;
       value = "R";
       //initial_focus = true;
     : edit_box {
       key = "dia";
       edit_width = 2;
       value = "6";
     : edit_box {
       key = "mark";
       edit_width = 3;
       value = "01";
     : edit_box {
       key = "spacing";
       edit_width = 3;
       value = "200";
   : boxed_row {
     label = "ww";
     : button {
       key = "accept";
       label = "  Okay  ";
       //is_default = true;
     : button {
       key = "cancel";
       label = "Cancel";
       is_default = false;
       is_cancel = true;
LISP code:
(defun c:test ( / dcl_id buttonPressed)
; Load dcl file.
(setq dcl_id (load_dialog "c:\\temp\\66.dcl"))
; Load dialog definition if it´s not already loaded.
(if (not (new_dialog "LINK1" dcl_id))
  (alert "Couldn´t find 66.dcl.")
  (exit)
(action_tile "accept" "(setq buttonPressed 0)(done_dialog)")
(action_tile "cancel" "(setq buttonPressed 1)(done_dialog)")
; Start dialogbox.
(start_dialog)
; Unload dialog.
(unload_dialog dcl_id)
Thanks for your codes.
Actually there is no any errors in codes.
Problem occurred after re installing the auto cad.
Okey, then i´m not that much of use. :unsure:
Hope someone with the right knowledge see you thread.
Merry Christmas btw! 8)
Maybe you should re-pair your CAD, or re-copy all *.dcl (base.dcl, acad.dcl...) of CAD
Try to search files include text
"LINK1"
contents to see problem
"LINK1"
Yes I will try
Merry Christmas all of you.
