pwned555 Posted December 20, 2011 Posted December 20, 2011 Recently I received some complaints about AutoCAD running fine and then periodically lagging at seemingly random times. When I looked at Computer Management->Event Viewer->Windows Logs->Application it seems like there is an error logged at the same time that the application begins to lag. The error details are as follows: Faulting application name: x64VBAServer18.exe, version: 18.1.49.0, time stamp: 0x4b72226d Faulting module name: ole32.dll, version: 6.1.7601.17514, time stamp: 0x4ce7b96f Exception code: 0xc0000005 Fault offset: 0x0003bc24 Faulting process id: 0x111c Faulting application start time: 0x01ccbe803e440ad5 Faulting application path: C:\Program Files (x86)\Common Files\Autodesk Shared\VBAServer\x64VBAServer18.exe Faulting module path: C:\Windows\syswow64\ole32.dll Report Id: 1d87ae7f-2a74-11e1-ac50-e0cb4eb974d2 It seems to be happening on most computers a couple of times a day. The faulting module name often differs. Quote
