ricoco Posted December 22, 2011 Posted December 22, 2011 Hi, Can anyone help me with this problem I am currently having? After a few hours of everything working perfectly, AutoCAD will suddenly decide to select objects slowly (for move, copy, trim, erase etc. commands). There will be a short time lag between picking a point on the screen and creating the selection box. The problem is only rectified by switching off the pc and rebooting. Any suggestions gladly welcomed! Quote
Mike_Taylor Posted December 22, 2011 Posted December 22, 2011 I always find the PURGE command helps me tremendously. Quote
ricoco Posted December 22, 2011 Author Posted December 22, 2011 Thanks Mike. Unfortunately I have tried purge and audit and problem still persists. I've also tried cutting and pasting the drawing into a new drawing but no joy. Quote
ReMark Posted December 22, 2011 Posted December 22, 2011 What are the specs on your computer? Are you working off a network or is this a standalone system? How large is the drawing file? Is this a 2D or 3D drawing? Are there xrefs involved? Do you have a bloated scalelist? Are you running an antivirus program that relies upon real time scanning of files? Quote
ricoco Posted December 22, 2011 Author Posted December 22, 2011 Hi, Thanks for your interest; answers (as best I can) below: What are the specs on your computer? Windows XP, 1.93GB Are you working off a network or is this a standalone system? standalone How large is the drawing file? doesn't just happen with one drawing but all drawings - each on average maybe 2 or 3 MB Is this a 2D or 3D drawing? 2D Are there xrefs involved? no Do you have a bloated scalelist? sorry dont know what that is but happens on all drawings eventually after a time Are you running an antivirus program that relies upon real time scanning of files? no Quote
SLW210 Posted December 22, 2011 Posted December 22, 2011 ScaleList Cleanup Utility Do you have all UPDATES? Quote
ReMark Posted December 22, 2011 Posted December 22, 2011 Your computer could be running low on resources given that you have 2GB RAM but it would depend on what else is running concurrently with AutoCAD in use. Quote
SLW210 Posted December 22, 2011 Posted December 22, 2011 Looks like 3GB recommended. AutoCAD Architecture 2008 System Requirements Intel® Pentium® 4 or AMD Athlon™ processor, 3 GHz or greater Microsoft® Windows® XP (SP2 or later) or 32-bit versions of Vista™ operating system 3 GB RAM 3.1 GB free disk space 1280x1024 monitor and display adapter capable of 32-bit color 128 MB or greater, OpenGL®-capable workstation-class graphics card MS Mouse—compliant pointing device Microsoft Internet Explorer 6.0 (SP1 or later) What graphics card do you have? Quote
ricoco Posted December 22, 2011 Author Posted December 22, 2011 Graphics card is 64MB VIA Chrome 9HC IGF Family. Quote
ReMark Posted December 22, 2011 Posted December 22, 2011 64MB? Is that a typo? Your system appears to be on life-support. I'd recommend either an upgrade or a replacement unless you just want to live with the problem. The problem goes away after turning off and rebooting your computer because you have flushed the memory. As your system runs longer it uses memory but does not release it thus the reason for the slowdown. You could try using a small utility program to recapture the lost memory but that does not negate the fact that your computer really is not up to the task at hand. Quote
ricoco Posted December 23, 2011 Author Posted December 23, 2011 OK, thanks for comments, much appreciated. Quote
ReMark Posted December 23, 2011 Posted December 23, 2011 A short term solution would be to add more memory, tweak the settings for virtual memory (i.e. - your swap file) and upgrade your graphics card provided you have the $$$ to do it. Quote
Dadgad Posted December 23, 2011 Posted December 23, 2011 (edited) Might reducing the INCREMENTAL SAVE PERCENTAGE be of any use, as it would reduce the file sizes by as much as say 1/3? Slower saves, but would that help minimize the demands on the system? Is your hardware acceleration turned off? Edited December 23, 2011 by Dadgad Quote
ReMark Posted December 23, 2011 Posted December 23, 2011 Anything might be of use at this point. The OP can flush memory using a utility called FreeRAM XP or another one called CleanMem. He might even try tweaking his virtual memory settings. Quote
Dadgad Posted December 23, 2011 Posted December 23, 2011 I routinely go in and tweak my virtual memory, usually helps. Quote
