Attached is a routine I use in conjunction with PDFCreator to batch print pdf drawings. The problem is I use Bricscad V12 and the latest changes they made have made this routine shut down because "qprint" is no longer using "previous" plot variable. I was wondering if any of you gurus out there might know how to adapt it to the "plot" command?
I figure using a script might be the way but don't know how to insert it. Any ideas?
Thanks ahead for any input! Below is the routine.
Code bprint:
(defun C:BPRINT (/ )
(if (not dos_dir) (arxload "DOSLib11.brx"))
(setq files (dos_getfilem "Select files to print.." "C:\\""Drawing Files (*.dwg)|*.dwg"))
(setq dwgpath (car files))
(if (/= files nil)
(foreach dwgfile (acad_strlsort (cdr files))
(command ".open" (strcat dwgpath dwgfile))
(command ".qprint")
(command ".qsave")
(command ".close")
Instead of qprint use the normal print and add all the settings required to plot a window and it should work.
Search for some of the PDF plot routines for the code examples. Look under BIGAL
