abevis Posted October 20, 2008 Posted October 20, 2008 I need some help please!!!!! I have a 3D model that i have created in AutoCAD 2009 and I want to import into Corel Draw. So i published them to a PDF. When I import them into Corel it will only import the the 2D wireframe but it will not import a conceptual model or realistic model. If I try it that it says the file is corrupted. Any ideas how i can get the conceptual model into corel for editing???????? Quote
rustysilo Posted October 20, 2008 Posted October 20, 2008 I'm guessing if you export it to a .dxf (likely an older version .dxf like R2000) Corel could then open or import it. Quote
shift1313 Posted October 20, 2008 Posted October 20, 2008 ive never used corel but if you are just looking for a picture of your model and not the actual model you can either take a printscreen, or you can use plot, and for the printer there is a publish to web jpeg and also a dwg to pdf option. hope this helps Quote
mugshot Posted October 23, 2008 Posted October 23, 2008 try setting your drawing base on your desire, render and soon as the image or render window appear, then save a copy as, this will save in .jpg file. Quote
mugshot Posted October 23, 2008 Posted October 23, 2008 try setting up your drawings in your desired view, render, as soon as render window appear, try to click on the save images ( or some sort of) then you go, save the image/s as .jpg. (cad '08) Quote
