How to Export text(Numbers) in Autocad to Excel ?
hi
i want to export Numbers in CAD to Excel by easy method !!!
i add one file attachment for EXample please see!!!
this file is Poject Cross Section & i want to export text in layer "C-Road-SCTN-TITL" with text in layer "Are-Block" to different cells in Excel
what can i do ?
For Example :
see excel file
Sorce DWG :
see DWg file
example.xls
part 1.dwg
It appears that you have plain Text and MText objects on the two layers. I've seen at least three different lisp routines that claim to be able to export plain text to Excel but I have no idea how well they work.
Something wrong with your layers
Here is quick and dirty lisp for your interest
(vl-load-com)
;;*** list to csv readable string ***
(defun list->csv(lst sep / join)
;;arguments
;; lst -list of string like: '("CENTER" "-4612.43" "5043.47" "1787.77")
;;sep - string (separator, i.e: ",")
;;return string like "CENTER,-4612.43,5043.47,1787.77"
(setq join (apply 'strcat (mapcar '(lambda (x)(strcat x sep)) lst))
join (vl-string-right-trim sep join))
join
(defun C:Tryit(/ contours datafile datalist fname mtext_list pt sectexts txs x)
(command "_zoom" "_e")
(if
(setq sectexts (ssget "X"
(list (cons 0 "mtext")
(cons 8 "C-ROAD-SCTN-TITL")
(cons 62 92)
(cons 40 2.0)
(cons 7 "Standard")
(cons 1 "*+*")
(cons 410 (getvar "ctab"))
(setq mtext_list
(mapcar 'vlax-ename->vla-object
(mapcar 'cadr
(ssnamex sectexts)))
(setq contours (mapcar '(lambda (x)
(if (setq pt (vlax-get x 'insertionpoint))
(cons (vlax-get x 'textstring)
(list (list (- (car pt) 24) (cadr pt))
(list (+ (car pt) 24) (cadr pt))
(list (+ (car pt) 24) (- (cadr pt) 24))
(list (- (car pt) 24) (- (cadr pt) 24))
mtext_list
(setq datalist
(mapcar
'(lambda (x)
(cons (car x)
(list (if
(setq txs
(ssget "wp" (cdr x) (list (cons 0 "text") (cons 8 "are-block") (cons 410 (getvar "ctab"))))
(vlax-get (vlax-ename->vla-object (ssname txs 0)) 'textstring)
(if
(setq txs (ssget "wp"
(cdr x)
(list (cons 0 "text") (cons 8 "are-block1") (cons 410 (getvar "ctab")))
contours
(setq fname (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".csv");<-- change on .xls
(setq datafile (open fname "W"))
(write-line "C-ROAD-SCTN-TEXT,are-block,are-block" datafile)
(foreach record datalist
(write-line (list->csv record ",") datafile)
(close datafile)
(getstring "\n\t\t *** Press Enter to open resulting file ***")
(startapp "C:\\Program1\\Microsoft Office\\Office14\\EXCEL.EXE"
(strcat "\"" fname "\""))
(prompt "\n\t\t >>> Start command with Tryit <<<")
(prin1)
Edited by fixo
What program were those cross sections generated in?
hi
i can't run in autocad ; i typing in command is "tryit" when i loaded
what can i do ?
(vl-load-com)
;;arguments
join
(if
(cons 62 92)
(cons 40 2.0)
(cons 7 "Standard")
(cons 1 "*+*")
(setq mtext_list
(mapcar 'cadr
mtext_list
(setq datalist
(mapcar
'(lambda (x)
(cons (car x)
(list (if
(setq txs
(if
(cdr x)
contours
(close datafile)
(startapp "C:\\Program Files\\Microsoft Office\\Office12\\EXCEL.EXE" (strcat "\"" fname "\""))
(prin1)
Working good on A2009 for me
Perhaps, it is needs to change your Excel.exe path:
mine is
What is the error you have got?
i take movie plaese see it and help me ; what can i do with error !!
my Excel.exe path is "C:\Program1\Microsoft Office\Office14\EXCEL.EXE"
plaease Help !!
file download :
http://www.mediafire.com/?cyuxi3ac98z3gy3
mine is
I had changed this line on your path within the code above, try again
Just to avoid troubles with Excel, try it for the quick test
It will output text file instead:
Command :Txtin
;;arguments
 join
(defun C:Txtin(/ contours datafile datalist fname mtext_list pt sectexts txs x)
(if
        (cons 62 92)
        (cons 40 2.0)
        (cons 7 "Standard")
        (cons 1 "*+*")
  (setq mtext_list
   (mapcar 'cadr
      mtext_list
    (setq datalist
    (mapcar
      '(lambda (x)
  (cons (car x)
        (list (if
         (setq txs
       (if
     (cdr x)
      contours
    (setq fname (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".txt");<-- change on .xls
 (write-line (list->csv record "\t")  datafile)
(close datafile)
;;(startapp "C:\\Program Files\\Microsoft Office\\Office12\\EXCEL.EXE" (strcat "\"" fname "\""))
  (startapp "NOTEPAD.EXE" (strcat "\"" fname "\""))
(prompt "\n\t\t   >>> Start command with Txtin   <<<")
(prin1)
(vl-load-com)
Both lisps work fine for me on the sample data file.
Termal, have a read of http://lee-mac.com/runlisp.html From the look of that video you posted it doesn't look like you are saving the lisp/running it properly.
thanks ; i am realy Sorry !!
Please accept my apologies .
but some sections are 2 area and this lisp are typeing one area ; what can i do typing two areas in note pad ?
Perhaps, change layer names in selection filter ,
I was using "are-block" twice in there
Sorry I'm busy now
