CADgirl Posted January 1, 2012 Posted January 1, 2012 Sometimes when I am trying to edit a layer's properties the changes won't take. For instance, if I want to change the color I will open up the color dialog box and select the new color. When I close it it hasn't changed. It takes a few times of doing this and even sometimes closing and reopening the layer properties window again. Does anyone know why this is happening to me? I am using AutoCAD 2006. Thanks! Quote
Dadgad Posted January 2, 2012 Posted January 2, 2012 I've never had that happen. Do you mean that the color indicated in the dialog box won't change, or that the color change you have made in the dialog box is not reflected on your display? You might want to try using the refresh button on the LAYER PROPERTIES MANAGER ................. just a guess, no harm in trying, right? Quote
ixyak Posted January 3, 2012 Posted January 3, 2012 make sure the color is "ByLayer" Uploaded with ImageShack.us Quote
