Hello everyone!
I have small problem. When I use hatch on certain area it also wants to hatch one closed area ,however other closed areas do not hatch. I rechecked , remade the closed area which is hatched along side with the area I really need to hatch.
So how can I isolate that little area? Or what is the problem?
Could the pattern be too large for the smaller area to be seen?
Nope.
I believe I explained myself not clearly. The problem is I have a little box 50x50 cm on plan inside huge area. I want to hatch that huge area. Problem is that it hatches not only this huge area but also that little box inside this area. I checked that area is closed, did it with polyline, still hatched... :S
Try changing your island detection parameters on your hatch dialog box. Sometimes small areas within large areas are treated as if they were island objects rather than boundary lines.
How are you hatching? Are you selecting an area or an object?
