Furion Posted January 3, 2012 Posted January 3, 2012 Hello. Drawing: line, arc, line. arc was defined with line's end points and radius, so I'm positive that this drawing is continous. Steps I take: pedit click do you wish to turn into polyline y j Select objects: 1 found Select objects: 1 found, 2 total [enter] Select objects: 0 segments added to polyline [enter] What am I doing wrong? I had no problem turning other arcs into polyline... cheers Furion Quote
Tharwat Posted January 3, 2012 Posted January 3, 2012 First convert the arc to polyline then connect at least one end point of a polyline and after choosing the join option give the fuzz value 0.0 and they would be connected . Good luck Quote
