hey guys,i have been trying to install autocad 2010 but i get this error always
does anyone has a solution to it? please help:(
2012/1/4:15:58:13 Sejal SEJAL-PC === Setup started on SEJAL-PC by Sejal ===
2012/1/4:15:58:46 Sejal SEJAL-PC === Setup started on SEJAL-PC by Sejal ===
2012/1/4:15:58:58 Sejal SEJAL-PC === Setup ended ===
2012/1/4:16:09:40 Sejal SEJAL-PC Install DirectX 9.0 Runtime Succeeded
2012/1/4:16:17:57 Sejal SEJAL-PC Install AutoCAD 2010 Failed Installation aborted, Result=1603
i am using windows 7 32-bit on my pc
But where can i find the deployment wizard any idea?
I'm guessing from your inquiry this was not a network deployment?
Is this a 32-bit AutoCAD?
Make sure you have administrator rights on the computer.
Try a clean UNINSTALL & REINSTALL of all Autodesk products.
Check with Microsoft Windows, could be a Windows 7 problem.
Error 1603 is difficult to resolve. It is general code for issue that unknown, usually Microsoft related.
Cleaning Autodesk product might help, but you might want to check these first:
1. Try to install prereq manually. I found most problem is when installing .NET framework. Install it manually FROM YOUR DVD. Different version of .NET will not work.
2. Also make sure you exit anti virus and everything that might interrupt installation.
