CAD-LOVER0208 Posted October 21, 2008 Posted October 21, 2008 Hello all again. hope all are doing good. Ok i have a problem, and the only place that i thought would help me is HERE .... Ok i designed a floor plan on AutoCAD Architectur 2009 with the scale of 1:200.... ( that's not a problem ) the problem is, that we have to make a model, and use the metric ruler, scale of 1:200, manual. the problem is that i DON'T know how to do that... i can't read it, i don't know how to start, for example, the car parking space is 2500 X 2600 mm , how do i start using the manual scale ? sorry if i'm not clear , it's just when i'm confused i get lost and don't know what to do.. thanks in advance Quote
Cad64 Posted October 21, 2008 Posted October 21, 2008 You created your drawing at a scale? Not 1:1? You should always drawing everything at 1:1. Autocad model space is infinite. There is no reason to ever draw anything at a scale. Quote
eldon Posted October 21, 2008 Posted October 21, 2008 If you are using a real live ruler, it is sooo much easier if you can get hold of a scale ruler. If you only have an ordinary ruler, then to make a 1 to 200 scale model, you have to divide all your dimensions by 200. Your parking bay would then have to measure (2500/200) by (2600/200) which is 12.5mm by 13mm. Quote
CAD-LOVER0208 Posted October 21, 2008 Author Posted October 21, 2008 Yes, I created my DWG on the scale of 1:200, that's what our teacher said we have to do . And i printed my floor plan and site plan DWG on a 24"X36" size paper, and I was hoping to build my model right on it.. So i am using this scale (i attached a pic. ) 1:200, and i was kind of not sure how to use it. Quote
eldon Posted October 21, 2008 Posted October 21, 2008 That looks as if the units are in metres. So each small division is 1/5th of a metre or 200 mm, and every 5 divisions there is a longer line which marks the metre division which are labelled every 5th line. Quote
