Hi, I needed to make a bunch of concentric circles (something like 30 or 40), and I used offset command;
I'm wondering if there's a way to 'array offset'? It's already done and wasn't that difficult, but I just
have to know.. thx!
have to know.. thx!
Here you have one. It's not perfect by any means but it works. On the prompt "Side to offset", you just have to pick point far enough. Try it, you'll see.
(defun c:ffs (/ a b e d f oecho)
 (initget 7)
 (setq	a (getint "\n Number of offsets: ")
b (getdist "\n Offset distance: ")
e (entsel "\n Select entity to offset: ")
d (getpoint "\n Side to offset: ")
f b
oecho (getvar "cmdecho")
 (setvar "cmdecho" 0)
 (repeat a
   (command "offset" b e d "")
   (setq a  (- a 1)
  b (+ b f)
 (setvar "cmdecho" oecho)
Edited by paulmcz
  • 5 years later...
Try this too...
(defun c:mof()
 (setq enty (car (entsel "\nPick Object:")))
 (setq ofs (getreal "\nOffset Value:"))
 (setq side (getpoint "\nSide to Offset:"))
 (setq reps (getint "\nRepeats:"))
 (setq i 1)
 (setq osm (getvar "OSMODE"))
 (setvar "OSMODE" 0)
 (repeat reps
   (command "_Offset" offset enty side "")
   (setq offset (* ofs i))
   (setq i (1+ i))
 (setvar "OSMODE" osm)
 (command "_REGENALL")
