Change justification of leader of multileader text
I don't normally deal with multileaders with text although a drawing I have has been done with these.
The leader is justified to the left of the text. If I drag the position of the leader head to the right hand side of the text, the leader still starts from the left hand side of the text (goes at the bottom of the text) so how would I justify the leader position of a multileader to the right hand side of the text?
I had a quick look in the properties pane earlier although am fairly busy and it is only a trivial issue. :)
Is this what you are looking for?
Leader Connection – Right Attachement: if your text is on the right, then this setting tells AutoCAD where to place the landing, center, top, bottom, etc.
Under the Text properties for multileaders, there should be a Justify value, which you can set to Left, Right, or Center.
mleaderstyle? I'm not sure if this is only available in Civil 3D, but all of the multileader attributes can be modified there.
