gracehazelby Posted October 21, 2008 Posted October 21, 2008 how in detail can I set autoCad2002 to feet and inches then width and length I am a complete new user of Cad Quote
hotrodz0321 Posted October 21, 2008 Posted October 21, 2008 type UNITS...select ARCHITECTURAL as your units what do you mean by width and length? are you talking about your drawing limits? Quote
gracehazelby Posted October 21, 2008 Author Posted October 21, 2008 drawing limits in feet and inches for grid screen in auto cad Quote
ReMark Posted October 21, 2008 Posted October 21, 2008 Use the LIMITS command to set the limits of your drawing. Most people stopped using this command ages ago. You'll be prompted for the lower left hand corner and upper right hand corner settings in an X, Y form. Use the GRID command to specify your grid spacing and use the SNAP command to specify your snap spacing. They don't necessarily have to be one and the same. Quote
hotrodz0321 Posted October 21, 2008 Posted October 21, 2008 to set your limits you just type LIMITS...your minimum corner is typically 0,0...your max is going to be in inches and according to your scale...a scale of 1"=1' on a 36x24 sheet would be 432,288...a scale of 1/4"=1' on a 36x24 would be 1728,1152...... what is your scale and what size sheet are you using? its been a long time since ive used the limits and stuff so someone correct me if im wrong. Quote
hotrodz0321 Posted October 21, 2008 Posted October 21, 2008 check it.....i dont have sound on my computer but this looks exactly like what need.....take a look and see if you can come up with a solution. Quote
Fritz Posted October 21, 2008 Posted October 21, 2008 If you're not totally comfortable with text commands yet, "units" is also an option in the "Format" pulldown menu. Quote
gracehazelby Posted October 22, 2008 Author Posted October 22, 2008 to set your limits you just type LIMITS...your minimum corner is typically 0,0...your max is going to be in inches and according to your scale...a scale of 1"=1' on a 36x24 sheet would be 432,288...a scale of 1/4"=1' on a 36x24 would be 1728,1152...... what is your scale and what size sheet are you using? its been a long time since ive used the limits and stuff so someone correct me if im wrong. this does not seem to work on my computer i did the width 432,288 and get no numerical value what I`m told is 12 metres width and 9 metres high but all the measurements I have is feet and inches Quote
ReMark Posted October 22, 2008 Posted October 22, 2008 Which template did you open? There is an Imperial and a Metric. Quote
mugshot Posted October 23, 2008 Posted October 23, 2008 ... why don't set it up on dimension properties also? Quote
gracehazelby Posted October 23, 2008 Author Posted October 23, 2008 as I said complete novice I am back to converting imperial to metric this I can manage Quote
ReMark Posted October 23, 2008 Posted October 23, 2008 But you shouldn't "have to convert" unless you are into masochism. Well, are you? Quote
