Ollie8974 Posted January 11, 2012 Posted January 11, 2012 I am taking some AutoCAD classes at the local community college, using AutoCAD 2012 Using privous versions of AutoCAD the copy with base point is in the on screen right click drop down window. To use the Copy With Base Point The Clip Board icon needs to be selected. anyone know how to get the Copy with Base Point and other paste commands in the drop down window as in all previous versions. Quote
ReMark Posted January 11, 2012 Posted January 11, 2012 You would have to edit the CUIx I believe. Quote
RobDraw Posted January 11, 2012 Posted January 11, 2012 It's still there. Just at a deeper level. Quote
JBullseye74 Posted January 11, 2012 Posted January 11, 2012 Alternatively use the shortcut Ctrl+Shift+C Quote
the ber Posted January 11, 2012 Posted January 11, 2012 Or you can display the "old" menus, above the ribbon. Quote
SLW210 Posted January 11, 2012 Posted January 11, 2012 You would have to edit the CUIx I believe. Yes and takes just 1 minute or less. _CUI Click the + sign on "Shortcut Menus", then Click the + sign on "Default Menu", then Click the + sign on "Clipboard", Ctrl select all the commands, then drag up to location you desire in the parent "Default Menu". Quote
