I need help for adaptive part
I have made a part (Flat Bar) with the length of the FB adaptive. When I insert the FB in my assembly, I made the FB adaptive and I place it between two metal sheet it take the length between them as wanted.
BUT I need multiple FB of the same size but not the same length and when I but another FB of the same size, I can't but this one adaptive? It keep the length of the first FB that I put in my assembly. But I need it to be of a different length. How can I do that without making a different part for each FB.
Adaptive parts/assemblies can only have a single definition (i.e. when you change the definition of one instance of the part it changes all of them). An assembly can be made "Flexible" and this allows you to change the definition for a single instance and not have it effect any of the others. We unfortunately do not have "flexible Parts", it is on the wishlist. You should look into iparts, that is the best option for what you are trying to do.
Ty for the quick respond.
It's looks like I'll do ipart... I hate those :x
