My native language is not English ,but I think you can understand my ideal .
Who can provide a lisp file to achieved this goal ?
Look at picture below:
hope this helps .....
(defun c:TesT (/ *error* acdoc ss p1 j sset e)
 ;;; Tharwat 16. jan. 2012 ;;;
 (vl-load-com)
 (defun *error* (msg)
       (princ (strcat "\n** Error: " msg " **"))
 (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)))
 (if (setq ss (ssget "_:L" '((0 . "TEXT"))))
     (vla-StartUndoMark acdoc)
     (setq p1 (cdr (assoc 10 (entget (ssname ss 0)))))
     (repeat (setq j (sslength ss))
       (setq sset (ssname ss (setq j (1- j))))
       (setq e (entget sset))
       (entmod
         (subst (cons 10 (list (car (cdr (assoc 10 e))) (cadr p1)))
                (assoc 10 e)
                e
 (vla-EndUndoMark acdoc)
I'm not commenting on issues with justification or not being able to actually choose which text object the user wishes to match. I just want you to reevaluate this portion of your code:
Consider a little less legwork:
Replace:
With:
(list 10 (cadr (assoc 10 e)) (cadr p1))
Think about the data structure when you extract it, the easiest way to manipulate it and how you want it to look in the end.
Granted, this doesn't take into account a Z elevation, but it's not particularly important for this lesson.
