I created a basic lisp routine to allow us to create multiple layout tabs (from a template) at one time. My problem is that I cant get it to go past 9 layouts before it messes up. For example our naming convention is AL101, when I ask it to go more than ten it starts naming them AL109, AL1010, AL1011 ect. I would like it to be AL110, AL111. I know its how I laid out the program but I don't have time to redo it and I know there are a lot of people on here that could probably fix it in a matter of minutes, so any help would be appreciated. Thanks.
(defun C:lrnp ( / lnum tnum lname lnamec lname2 lname3 lname4 lname5 lname6 lname7 lname8 tmplt)
(setvar "tilemode" 1) ;changes to model space
(setq lnum(getint "\HOW MANY LAYOUTS DO YOU WANT TO CREATE? ")) ;prompt for number of layouts
(setq tnum(1- lnum))
(setq lname(getstring "\What is the naming convention (ie E1.1) :")) ;get naming convention
(setq lnamec(strlen lname)) ;counts number of characters in naming convention
(setq lname2(substr lname lnamec)) ;takes the last character of naming convention
(setq lname4(atoi lname2))
(setq lname8(+ lname4 lnum))
(SETQ TMPLT(GETSTRING "\SELECT LAYOUT FOR TEMPLATE (8.5x11) (11x17) (24x36): " )) ;requests paper size
(COMMAND "LAYOUT" (WRITE-LINE "T" SCRFILE) (WRITE-LINE "NTL Project Template (May 2010).dwt" SCRFILE) (WRITE-LINE TMPLT SCRFILE)) ;gets layout from main templait
(command "layout" (write-line "r" scrfile) (write-line tmplt scrfile) (write-line lname scrfile)) ;rename first created layout
(setq lname5(substr lname 1 (1- lnamec)))
(repeat tnum
   (setq lname8 (1- lname8 ))
   (setq lname6(itoa lname8 ))
   (setq lname7(strcat lname5 lname6))
   (command "layout" (write-line "c" scrfile) (write-line lname scrfile) (prin1 lname7)) ;copys layouts
(princ "\Type 'LRNP' to run")
(PRINC)
Edited by JJtre
I did a post similar the other day for the same type of thing a couple of things though
I used layout "N" then a name very simple can do as many as you like
The layout name would be better as a strcat alpha characters + number characters then the number would just increase as part of the repeat function.
Now where is it.
http://www.cadtutor.net/forum/showthread.php?65411-Match-Line-Refer-Dwg.-No./page2&highlight=layout
example of strcat (setq layoutname (strcat alpha (rtos numlayouts 2 0)))
Edited by BIGAL
