Hi all,
I often need to work on big drawings having utility networks, topographic surveys and properties. Whenever using FIND command in such a drawing AutoCAD regens the drawing. This happens even if FIND command is cancelled and takes 2 to 3 seconds everytime. Can I disable this automatic regen and do only when I need.
Thanks.
You can try resetting REFENAUTO to "Off".
From your AutoCAD HELP file:
Inhibits regeneration of the drawing until you use the REGEN or REGENALL command, or set REGENAUTO to on. If you perform an action that requires a regeneration and that action is irrevocable (such as thawing layers), the following message is displayed:
Regen queued
If you perform an action that requires a regeneration and that action is revocable, the following message is displayed:
About to regen—proceed?
If you click OK, the drawing is regenerated. If you click Cancel, the last action is cancelled and the drawing is not regenerated.
Thank you very much, ReMark. You people are really helpful.
You're entirely welcomed. :)
We do what we can.
