ahyin Posted January 19, 2012 Posted January 19, 2012 Dear Sir, I'm new in vb.net, I try to load the sample file from AutoCAD .net training and got the following error message, anything in my AutoCAD setting. Thanks ! Cannot load assembly. Error details: System.BadImageFormatException: Could not load file or assembly 'file:///C:\Documents and Settings\CAD\desktop\AutoCAD .NET Training\Labs_Complete\vbNET\Lab1_Complete\bin\Release\Lab1_Complete_2010.dll' or one of its dependencies. This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded. File name: 'file:///C:\Documents and Settings\CAD\desktop\AutoCAD .NET Training\Labs_Complete\vbNET\Lab1_Complete\bin\Release\Lab1_Complete_2010.dll' at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) at System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) at System.Reflection.Assembly.InternalLoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, StackCrawlMark& stackMark) at System.Reflection.Assembly.LoadFrom(String assemblyFile) at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName) at loadmgd() Warning: The switch assembly binding logging OFF。 To record the assembly binding failures, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD)set as 1。 Note: failure to bind with the components of records related to the performance will be part of the negative impact To turn this feature off, remove the registry value[HKLM\Software\Microsoft\Fusion!EnableLog] Quote
SEANT Posted January 19, 2012 Posted January 19, 2012 It may be a .NET Framework version issue. For instance, if the VB.NET project targeted .NET framework 3.5, for AutoCAD 2010 or 2011, it would fail to load into AutoCAD 2007, which requires Framework 2.0. Quote
ahyin Posted January 20, 2012 Author Posted January 20, 2012 It may be a .NET Framework version issue. For instance, if the VB.NET project targeted .NET framework 3.5, for AutoCAD 2010 or 2011, it would fail to load into AutoCAD 2007, which requires Framework 2.0. Thanks for reply , I'm using AutoCAD 2011 and .NET framework 4.0. Quote
SEANT Posted January 20, 2012 Posted January 20, 2012 A Visual Studio project for AutoCAD 2011 should target .NET Framework 3.5, if I recall correctly. Quote
ahyin Posted January 26, 2012 Author Posted January 26, 2012 A Visual Studio project for AutoCAD 2011 should target .NET Framework 3.5, if I recall correctly. Thanks ! I will download .NET Framework 3.5 to try. Quote
SEANT Posted January 26, 2012 Posted January 26, 2012 Thanks ! I will download .NET Framework 3.5 to try. If you are using Architecture 2011 then you already have .NET Framework 3.5 installed. What may need to be done is to confirm that the Visual Studio project containing that training file has 3.5 set as the target framework. See Image. Quote
