Hi all,
I would like to create a shortcut that would insert a specific block. The block(s) are dwgs located on the C drive so I would like to basically type: car [space] and have the car block inserted.
Thanks in advance for any help!
You should be able to use a script for that.
Use -INSERT for command line only. AutoCAD help has a good section on scripts as well as plenty of info on CADTutor.
Ok thanks, so my script would read:
'-insert
car
___
Now how can I make it so that 'car [space]' inserts the block?
Thanks
You need to add this to your startup lisp. If stuck acad.mnl
(defun C:car ()
(command "'_insert" "car")
Personally I would look at palettes or menu's.
I would look at the toolpalletes as well.
With a routine like above, you'll have to add the folder of blocks into your support path.
Tool Palettes and/or Design Center is what I use as well.
