DavidWilbourn Posted January 23, 2012 Posted January 23, 2012 I am trying to write a *simple* DXF export procedure in a Delphi program. I can generate PolyLines, Text and Circles OK but am having real problems with Ellipses. No matter what I put for the posn & axis, I just get a tiny circle drawn at 0,0. Oddly one DXF viewer (online) does show the ellipse correctly but 3 others do not. Because this is a very simple application, I have not bothered with a Header (or Block & Table) section but from what I have read that should not be a problem. I have attached the test DXF I have created. Any suggestions would be gratefully appreciated! ellipse2.dxf Quote
SLW210 Posted January 24, 2012 Posted January 24, 2012 I cannot open your drawing in AutoCAD. I get this message on the command line... POLYLINE requires a 66 group on line 22.Invalid or incomplete DXF input -- drawing discarded. Quote
DavidWilbourn Posted January 24, 2012 Author Posted January 24, 2012 Thanks for trying, As I mentioned, I have tried this file in 4 different DXF viewers / editors now and they all read the file but give very different results. I am sure I will not be the first to comment that DXF is about the most un-standard standard I have ever seen! Having tried out a range of programs, the consensus seems to be to export everything as POLYLINEs. I have done that for Bezier curves and rectangles and have just done a first version of an Ellipse to Polyline conversion. That seems to work OK for my needs. David. Quote
DamianHaynes Posted August 23, 2012 Posted August 23, 2012 Hi David, I am exporting to DXF from a GDI Canvas and I am having the exact same issue, the Ellipse just goes to the very bottom in a small circle. Would you be willing to share your conversion code? cheers, Damian. Quote
