trmg Posted January 27, 2012 Posted January 27, 2012 With this LISP Im trying to make under floor heating. I think i am close to finishing it, but some error occurs in the end. Im trying to explode the last selection set but to do that google told me that you need to (setvar "qaflags" 1), and i think it's there that i don't follow. What is wrong and how to solve it? Please note that Im new to LISP and programming in general. If you took an extra minute to explain what i did wrong i would really appreciate it. Also, Im sorry if the code looks really bad, as i said i am new to this. Attaching a .dwg containing a block that is used in the lisp, so you can try it. gv.dwg (defun c:gt (/ lastEnt ss) ;; Save the last entity (setq lastEnt (entlast)) ;; Underfloorheatinghorizontal (setq pt1 (getdist "\nSpecify length of room")) (setq pt2 (getdist "\nSpecify height of room")) (setq pt3 (getpoint "\nSpecify lower middlepoint of room")) (command "-insert" "1" "x" (-(* pt1 3) 300) "y" "300" pt3 "0") (command "move" "l" "" "d" "0,50,0") ;;; ROUND ;;; (round pi 0.01) -> 3.14 ;;; (round pi 1e-5) -> 3.14159 ;;; (round 5456.50 1) -> 5457 ;;; (round 5456.50 100) -> 5500 (defun round (num prec) (* prec (if (minusp num) (fix (- (/ num prec) 0.5)) (fix (+ (/ num prec) 0.5)) ) ) ) (command "_array" "l" "" "rectangular" (round (/ pt2 600) 1) "1" "600") (setq ss (ssadd)) (while (setq lastEnt (entnext lastEnt)) (ssadd lastEnt ss) (sssetfirst nil ss) ;Grip select the set (setq OldQa (getvar "QAFLAGS" ) ) (setvar "QAFLAGS" 5 ) (command "._explode" SelSet) (setvar "QAFLAGS" OldQa ) ) (princ) ) Quote
pBe Posted January 28, 2012 Posted January 28, 2012 (defun c:gt (/ lastEnt ss) (setq pt1 (getdist "\nSpecify length of room")) (setq pt2 (getdist "\nSpecify height of room")) (setq pt3 (getpoint "\nSpecify lower middlepoint of room")) (command "-insert" "1" "x" (- (* pt1 3) 300) "y" "300" pt3 "0") (command "move" "l" "" "d" "0,50,0");<not sure whats this for (defun round (num prec) (* prec (if (minusp num) (fix (- (/ num prec) 0.5)) (fix (+ (/ num prec) 0.5)) ) ) ) [color=blue][b](setq lastEnt (entlast)[/b][/color] [color=blue][b] ss (ssadd))[/b][/color] [color=blue][b](command "._explode" "L" "")[/b][/color] (command "_[b][color=blue]-[/color][/b]array" [color=blue][b] "P"[/b][/color] "" "rectangular" (round (/ pt2 600) 1) "1" "600") (while (setq lastEnt (entnext lastEnt)) (ssadd lastEnt ss)) (sssetfirst nil ss) ;Grip select the set (princ) ) Quote
trmg Posted January 28, 2012 Author Posted January 28, 2012 The move command is because i couldnt figure out how to use 50y above pt3. Wow, thank you it does seem to work now. I still cant figure out how to select created items for use in next commands. I would also like to pedit the selection and fillet it with a radius of 150. Any input on that? Quote
pBe Posted January 29, 2012 Posted January 29, 2012 (edited) Use variable ss (defun c:gt (/ lastEnt ss pt1 pt2 pt3 i e ang) (defun round (num prec) (* prec (if (minusp num) (fix (- (/ num prec) 0.5)) (fix (+ (/ num prec) 0.5)) ) ) ) (if (and (setq pt1 (getdist "\nSpecify length of room")) (setq pt2 (getdist "\nSpecify height of room")) (setq pt3 (getpoint "\nSpecify lower middlepoint of room")) ) (progn (command "-insert" "1" "x" (- (* pt1 3) 300) "y" "300" pt3 "0") (command "move" "l" "" "d" "0,50,0") ;<not sure whats this for (setq lastEnt (entlast) ss (ssadd)) (command "._explode" "L" "") (command "_-array" "P" "" "rectangular" (round (/ pt2 600) 1) "1" "600") (while (setq lastEnt (entnext lastEnt)) (ssadd lastEnt ss)) ;(sssetfirst nil ss) [color=blue](repeat (setq i (sslength ss))[/color] [color=blue] (setq e (ssname ss (setq i (1- i)))[/color] [color=blue] Ang (apply 'angle[/color] [color=blue] (setq se (mapcar '(lambda (j)[/color] [color=blue] (cdr (assoc j (entget e))))[/color] [color=blue] '(10 11)))))[/color] [color=blue] (if (not (apply 'or (mapcar 'zerop (list i ang))))[/color] [color=blue] (progn[/color] [color=blue] (entmakex[/color] [color=blue] (list (cons 0 "ARC")[/color] [color=blue] (cons 10 (mapcar[/color] [color=blue] (function[/color] [color=blue] (lambda (a b) (/ (+ a b) 2.)))[/color] [color=blue] (car se)[/color] [color=blue] (cadr se)))[/color] [color=blue] '(40 . 150)[/color] [color=blue] (cons 50 (if (equal[/color] [color=blue] ang[/color] [color=blue] (/ pi 2.0) 0.1)[/color] [color=blue] (* pi 1.5)[/color] [color=blue] (/ pi 2.0)))[/color] [color=blue] (cons 51 Ang)[/color] [color=blue] ))[/color] [color=blue] (entdel e)[/color] [color=blue] (ssdel e ss)[/color] [color=blue] (ssadd (entlast) ss)[/color] [color=blue] )[/color] [color=blue] )[/color] [color=blue] )[/color] [color=blue] (command "_pedit" "_multiple" ss "" "_Yes" "_join" "" "")[/color] [color=blue] )[/color] ) (princ) ) Not sure if this is what you want though. EDIT: if you guys are wondeering about this (not (apply 'or (mapcar 'zerop (list i ang)))) On testing phase (since i'm unsure of the OPS final result will be) I redfined block "i" from his example drawing (not attached here). that way the first vertical line will remain and the rest would be an arc. Edited January 29, 2012 by pBe info Quote
trmg Posted January 29, 2012 Author Posted January 29, 2012 (repeat (setq i (sslength ss)) (setq e (ssname ss (setq i (1- i))) Ang (apply 'angle (setq se (mapcar '(lambda (j) (cdr (assoc j (entget e)))) '(10 11))))) (if (not (apply 'or (mapcar 'zerop (list i ang)))) (progn (entmakex (list (cons 0 "ARC") (cons 10 (mapcar (function (lambda (a b) (/ (+ a b) 2.))) (car se) (cadr se))) '(40 . 150) (cons 50 (if (equal ang (/ pi 2.0) 0.1) (* pi 1.5) (/ pi 2.0))) (cons 51 Ang) )) (entdel e) (ssdel e ss) (ssadd (entlast) ss) ) ) ) I have no idea what happens here but it does the job. Thank you so much for the help. I have to get to reading now so i will understand what the code does there. Quote
