create a polyline from points
is there a command (or method) that will create a polyline from selected cogo points instead of manually connected each point from a create line command?
thanks!
You can create a line of best fit although that won't pass through every point. The problem is how does the program know which points to join (unless using sequential point numbers) and in what order?
