Trying to work out how to select objects with vba
The line
[color=#000080]Set[/color] acSelSet ThisDrawing.SelectionSets.Add = ("Test")
throws up an error when I try to run this sample code from http://www.cad.dp.ua/stats/a_vba/acentity.php#AddEntToSS
Public Sub AddEntToSS ()
  Dim acSelSet As AcadSelectionSet
  Dim intCnt As Integer
 Dim objArray (0) As Object
 Dim AnyObj As AcadEntity
  Dim AnyPnt As Variant
 Set acSelSet ThisDrawing.SelectionSets.Add = ("Test")
 acSelSet.SelectOnScreen
 intCnt = acSelSet.Count
 MsgBox "There are" & intCnt & _
 "Entities in the new Selection Set"
 ThisDrawing.Utility.GetEntity AnyObj, AnyPnt, _
 "Pick an Entity to Add to the Selection Set:"
 Set objArray (0) = AnyObj
 acSelSet.AddItems objArray
 MsgBox "Now there are" & intCnt & _
   ThisDrawing.SelectionSets.Item ("test"). Delete
End Sub
Can anyone tell me why that is (incompatible with 2012 API syntax?) and how I would fix it?
What I am trying to do is work out (from example code I've found) how to select polylines and examine their elevation property.
You can use filters to select certian objects just like ssget, this bit of code example is for blocks do not have a pline
Dim SS As AcadSelectionSet
Dim objENT As AcadEntityDim FilterDXFCode(0) As Integer
Dim FilterDXFVal(0) As Variant
FilterDXFCode(0) = 0
FilterDXFVal(0) = "INSERT"
'FilterDXFCode(1) = 2
'FilterDXFVal(1) = "SCHEDTEXT"
Set SS = ThisDrawing.SelectionSets.Add("pit1sel")
SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
then maybe
If SS.Item(Cntr).Name = BLOCK_NAME Then
this may help a bit more
For Each ent In ssetpick
   Select Case ent.EntityType
       Case acPolylineLight
           Select Case ent.Layer
       Case layer1
           ent.Highlight (True)
           ent.Update
           'MsgBox "You selected a poly line"
           intVCnt = 0
           varCords = 0
           varVert = 0
           varCord = 0
           varNext = 0
           intCrdCnt = 0
           dblTemp = 0
           dblArc = 0
           dblAng = 0
           dblChord = 0
           dblInclAng = 0
           dblRad = 0
           varCords = ent.Coordinates
           For Each varVert In varCords
               intVCnt = intVCnt + 1
           Next
               For intCrdCnt = 0 To intVCnt / 2 - 1 'For LWPoly 2 - 1
                   If intCrdCnt < intVCnt / 2 - 1 Then
                       If ent.GetBulge(intCrdCnt) = 0 Then
                           varCord = ent.Coordinate(intCrdCnt)
                           varNext = ent.Coordinate(intCrdCnt + 1)
                           'computes a simple Pythagorean length
                           dblTemp = dblTemp + Sqr((Sqr(((varCord(0) - varNext(0)) ^ 2) + _
                           ((varCord(1) - varNext(1)) ^ 2)) ^ 2))
                           ' + ((varCord(2) - varNext(2)) ^ 2)) for 3D
                       Else
                           'If there is a bulge we need to get an arc length
                           dblChord = Sqr((Sqr(((varCord(0) - varNext(0)) ^ 2) + _
                           '+ ((varCord(2) - varNext(2)) ^ 2)) For 3D
                           'Bulge is the tangent of 1/4 of the included angle between
                           'vertices. So we reverse the process to get the included angle
                           dblInclAng = Atn(Abs(ent.GetBulge(intCrdCnt))) * 4
                           dblAng = (dblInclAng / 2) - ((Atn(1) * 4) / 2)
                           dblRad = (dblChord / 2) / (Cos(dblAng))
                           dblArc = dblInclAng * dblRad
                           dblTemp = dblTemp + dblArc
                       End If
                   End If
 Next
       lengthPoly = lengthPoly + dblTemp
       End Select
   End Select
Next
I can't test it here but, what happens if you make this change:
Set acSelSet = ThisDrawing.SelectionSets.Add("Test")
