Error in rule (ilogic component)
Hi, I made a set of conveyors legs using ilogic to change the width and elevation. THe problem is I keep getting an error whan I use the place ilogic component.
Error in rule: SIZING, in document: 30-0016-0A-01.iam
Parameter: The component named "30-0016-1A:1" was not found.
More Info:
System.ArgumentException: Parameter: The component named "30-0016-1A:1" was not found.
at iLogic.ParamDynamicFinder.ThrowException(String callerName)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
here is the sizing rule:
Parameter("30-0016-1A:1", "Elevation")=Elevation
Parameter("30-0016-1A:2", "Elevation")=Elevation
Parameter("30-0266-0A:1", "Width")=Width
those components do exist and are in the assembly.
I really need help
It seems it work if the assembly is in the same file as my ilogic assembly but I'd like to keep a structure in my file...
Edited by dgaudreau
this is what I would eventually like to do, but I'd like to maintain a structure in my files and be able to place diferent conveyor size into an assembly file
