Get the block name by picking it using VB.net
AutoCAD 2010+ and VB.net
How does someone get the block name in a drawing by picking the block reference in
the drawing using vb.net?
Thank you,
Consider this example from Kean's site (converted C#->VB.NET), paying special attention to the GetSelection Method:
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Namespace MyApplication
   Public Class DumpAttributes
       <CommandMethod("LISTATT")> _
       Public Sub ListAttributes()
           Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
           Dim db As Database = HostApplicationServices.WorkingDatabase
           Dim tr As Transaction = db.TransactionManager.StartTransaction()
           ' Start the transaction
           Try
               ' Build a filter list so that only
               ' block references are selected
               Dim filList As TypedValue() = New TypedValue(0) {New TypedValue(CInt(DxfCode.Start), "INSERT")}
               Dim filter As New SelectionFilter(filList)
               Dim opts As New PromptSelectionOptions()
               opts.MessageForAdding = "Select block references: "
               Dim res As PromptSelectionResult = ed.[color=red][b]GetSelection[/b][/color](opts, filter)
               ' Do nothing if selection is unsuccessful
               If res.Status <> PromptStatus.OK Then
                   Return
               End If
               Dim selSet As SelectionSet = res.Value
               Dim idArray As ObjectId() = selSet.GetObjectIds()
               For Each blkId As ObjectId In idArray
                   Dim blkRef As BlockReference = DirectCast(tr.GetObject(blkId, OpenMode.ForRead), BlockReference)
                   Dim btr As BlockTableRecord = DirectCast(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                   ed.WriteMessage(vbLf & "Block: " + btr.Name)
                   btr.Dispose()
                   Dim attCol As AttributeCollection = blkRef.AttributeCollection
                   For Each attId As ObjectId In attCol
                       Dim attRef As AttributeReference = DirectCast(tr.GetObject(attId, OpenMode.ForRead), AttributeReference)
                       Dim str As String = ((vbLf & "  Attribute Tag: " + attRef.Tag & vbLf & "    Attribute String: ") + attRef.TextString)
                       ed.WriteMessage(str)
                   Next
               Next
               tr.Commit()
           Catch ex As Autodesk.AutoCAD.Runtime.Exception
               ed.WriteMessage(("Exception: " + ex.Message))
           Finally
               tr.Dispose()
           End Try
       End Sub
   End Class
End Namespace
Source: http://through-the-interface.typepad.com/through_the_interface/2006/09/getting_autocad.html
HTH
Sorry, the code went to being all on one line after I posted; code has been reformatted in the above post.
