I'm having a problem with my hatch lines coming out too close unless I scale them up (x1000 +).
I've set the ltscale of the model drawing drawing to 1 and have selected ANSI31 hatch pattern.
I don't have this problem usually.
All other line styles look ok but I don't know why I'm having to use such a large scaling factor.
Is the 1000+ what you put in the hatch scale dialogue box? Try posting the dimensions of the object you want to hatch and a screenshot of your hatch screen (shift-printscreen).
the uploaded shot is the default hatch option. You could also try a different hatch pattern.
LTSCALE has no effect on hatches.
What is HPSCALE set to?
HPSCALE is set to 1
Yes - i'm having to put 1000 (or more) in the hatch scale dialogue box. The dims of the object are 4000 x 5000mm
what scale are you using anyway? try midifying your dimension style, look for the scale.
... sometimes using a scale of 1000, it means that you start from mm. so your hatches must be done also in mm.
