JerryG Posted October 22, 2008 Posted October 22, 2008 Hi all! Using Data Connect I have added a SDF connection to Lidar data and created contours of the site. It looks great and all but can I turn this data into a surface? I know I can create a surface from the contours but I'm looking for something more accurate. Thank you! Quote
BOB'27T Posted October 22, 2008 Posted October 22, 2008 I just use the lidar contours and make them into a surface. I've had really good success thus far. Quote
JerryG Posted October 22, 2008 Author Posted October 22, 2008 Thanks bob - but is it accurate enough? I can see surface imperfections that the contours dont seam to pick up. I set to Major Contours at 4' - am I possibly missing a setting? Thank you for the help! Quote
BOB'27T Posted October 22, 2008 Posted October 22, 2008 I set mine to 5', maybe that will make a difference. Quote
rustysilo Posted October 22, 2008 Posted October 22, 2008 You might need to mess with your weeding/supplementing factors as well as performing surface edits after adding the contour data to your surface such as swapping edges. When you add the contours I think you can set it to "minimize flat areas by..." and check the options you want to include. What is in the lidar data? Is it points? Could you perhaps upload the sdf file? I've never had a chance to play with one of those as our topo is always conventional survey data. Quote
JerryG Posted October 22, 2008 Author Posted October 22, 2008 Not points but more of a GIS based system like metadata. Sorry it wont let me load an ADF file. (orginal format). Unfortunatly I dont have the option to minimize flat areas since it is not a surface I'm creating contour data from. Its more of a image with Z values. (I think - still trying to grasp it all) The forum wont let me upload the file. Sorry. Quote
JerryG Posted October 22, 2008 Author Posted October 22, 2008 I just started from sctratch again and noticed that the orginale file is actually a adf file (sorry for the confusion) It dosn't create a SDf file until you create contour data from the image. Quote
rustysilo Posted October 22, 2008 Posted October 22, 2008 Ah I see. Maybe a small tutorial on creating contours from this data. Some of us have never used such file formats and created contours this way. Quote
JerryG Posted October 22, 2008 Author Posted October 22, 2008 You bet...as soon as I figure it out more completly I'll write something up. This is really new to me also. Its something our GIS expert recomended so I thought I would give it a shot. My orginal idea was have hime convert it to a point file (from Lidar data) then just delete areas i didn't need. But by doing it this way you can clearly see your site and its a much more managable Dwg. (no crashes or slowdowns) BTW - tried emailing you file but dont see anywhere to attach file under Send Email or Send PM ?? I must be missing something simple? Quote
rustysilo Posted October 22, 2008 Posted October 22, 2008 I guess you'd have to email, then I can reply which would allow you to reply back and attach via your email client. Quote
miken Posted November 5, 2008 Posted November 5, 2008 I think you're working with DEM (digital elevation model) data. Is it a grayscale image? Each grayscale represents an elevation, the program just de-codes that. Are you using Civil3d. If so, once imported just create the contours, the surface is already made. Mike - Quote
JerryG Posted November 5, 2008 Author Posted November 5, 2008 Right mike. I was able to get that far fairly easily. But the contours are not picking up all the grade slopes as they really exist. Is there a way to put the contours in at say a 2' intervale as opposed to 5' and 10' ? There are allot of areas on the image where I can see a small hill etc. but the contours are not picking it up. Quote
miken Posted November 6, 2008 Posted November 6, 2008 Yes, in the toolspace, under Surfaces, right click and select Create Surface. On the dialog you should see a Style and to the right it should say Standard, click the little box and another dialog opens. Click the little box with the pencil and the Surface Style editor opens. Find the words Contour Intervals on the Contour tab. For minor set it to 2 feet. You can save various styles. 2 and 5's, 5's and 10's etc. Hope this helps. Mike - Quote
giraffeking Posted May 18, 2012 Posted May 18, 2012 Hi guys, I know this is an old thread but I was hoping for a little bit of clarification. I'm loading massive point cloud files (.las) to my Civil3d drawings and it's taking forever. I really only need small parts and am planning on clipping them (I'm also not sure of how I'm going to do this), but really, should I be waiting 30min for these point clouds to load? Any other way I could do this? I am also going to be turning them into contour lines.. Thanks in advance Quote
Emigrato Posted May 18, 2012 Posted May 18, 2012 Which commands do you use to load that .LAS file? Quote
miken Posted May 18, 2012 Posted May 18, 2012 Hi guys, I know this is an old thread but I was hoping for a little bit of clarification. I'm loading massive point cloud files (.las) to my Civil3d drawings and it's taking forever. I really only need small parts and am planning on clipping them (I'm also not sure of how I'm going to do this), but really, should I be waiting 30min for these point clouds to load? Any other way I could do this? I am also going to be turning them into contour lines.. Thanks in advance In my experience it does take a huge amount of time to load .las files. We have a guy with Merrick Mars Explorer software, which is used to edit and process our .las point cloud data prior to importing directly into Cad. Applied Imagery Terrain Modeler is another software. Mike - Quote
giraffeking Posted May 18, 2012 Posted May 18, 2012 I'm just entering it in through the Home tabCreate Ground Data panelCreate Point Cloud. And it really does take a really long time to update after I've entered it. Miken, I think I'll look into that software, but I'm curious if you know how to clip point data to certain lats/longs? I've tried the conventional methods and it doesn't work (not that I thought I would but I thought I'd give it a shot) I Just need a small section so even if after the long loading time if I could cut out 90% of the point cloud it would really help in not bogging down the program so much. Quote
