I try to copy with control-c and then paste and object.
the problem is that it won't let me use the control-c function on
the dwg file I am working. Never seen this. Is there a lock fucncion
or something?
thanx.
hmm interesting...cuz I get that soemtimes but only with certain drawings.....
for usually when i ctrl+c a drawing or an object it takes about a second to take then I can paste it
but in some drawings I ctrl+c then and pick and it highlights but it doesnt process it so when I try to paste it, it doesnt work..
Im thinking there's a lock feature like u asked, but I dont know it
any help would be appreciated :? :?
Try this: Using the menu,
Tools>>Options>>User Preference>>Windows Standard behavior,
check "Windows Std accelerator keys"
doesnt do anything for me
I get this maybe this is why
ARX_ERROR: eNotThatKindOfClass
> chubster41 : I think this error generated by Proxy-objects. You can't copy-paste proxy objects. But if you'll explode them, contents of proxy-objects will be available for Copy-Paste operations.
Hmm, I'm probably showing my age, but 'ctrl+c' used to mean cancel, same as 'esc'. I'm sure things have moved on
  • 2 years later...
I have this troubles with ctrl+c and ctrl+v too. Finally I find out that it is block maked from 3d objects contains ARX objects. When I explode that block or remove it from the selection, ctrl+c and ctrl+v works correctly.
