Ahankhah Posted February 2, 2012 Share Posted February 2, 2012 Hi All, how is possible to find out what is the current Line weight? I appreciate any help:) Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted February 2, 2012 Share Posted February 2, 2012 Current LineWeight is stored in celweight SysVar. -1 means "Bylayer"; -2 is "ByBlock; -3 is "Default". But if you want the value of current LineWeigth try this (if (minusp (setq celw (getvar 'celweight))) (nth (+ 3 celw) (list (getvar 'lwdefault) "ByBlock" (vla-get-Lineweight (vla-item (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) (getvar 'clayer))) ) ) celw ) "Byblock" has no meaning until you use newly created object in a block and set Lweight for that block. And keep in mind that the value returned is 100 times the real value (25 instead 0.25, for metric units) Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted February 2, 2012 Author Share Posted February 2, 2012 Stefan BMR, thank you very much. Quote Link to comment Share on other sites More sharing options...
